Custom winget
added custom gauge winget but nothing comes up in settings to adjust or view ranges and selecting corors for ranges at bottom of settings have used it before not sure why it is not coming up
i am not sure why the setting does not open up. can you try this. first delete the widget from the dashbboard. next, add the below lines in your code.
 unsigned long lastMillis = 0;
    lastMillis = millis();
    Cayenne.virtualWrite(1, x, "analog_sensor", "null");
where x is the value you want to show on the dashboard.
when you upload the code this will create a temporary widget on your dashboard. add it and click settings. change choose widget to gauge and do the changes you want.
where in code is this placed and do i need to add this for every sensor gauge? Not sure what you mean by x is value i want i callibrated sensors 5 as dry and 615 as wet
here is my code
//#define CAYENNE_DEBUG
//#include <CayenneMQTTEthernet.h>
#include <CayenneMQTTEthernetW5500.h>
 #include <OneWire.h>
char username[] = "xxxx";
char password[] = "xxxx";
char clientID[] = xxxx";
#define SENSOR_PIN0 A0
#define VIRTUAL_CHANNEL1 1
#define SENSOR_PIN1 A1
#define VIRTUAL_CHANNEL2 2
#define SENSOR_PIN2 A2
#define VIRTUAL_CHANNEL3 3
#define SENSOR_PIN3 A3
#define VIRTUAL_CHANNEL4 4
#define VIRTUAL_CHANNEL5 5
#define VIRTUAL_CHANNEL6 6
const int tmpPin6 = 6;
const int tmpPin5 = 5;
OneWire oneWire6(tmpPin6);
OneWire oneWire5(tmpPin5 );
DallasTemperature sensors6(&oneWire6);
  sensors5.begin();
  sensors6.begin();
CAYENNE_OUT(VIRTUAL_CHANNEL5)
  //Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors5.getTempCByIndex(0));
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL5, sensors5.getTempFByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL6)
  sensors6.requestTemperatures();
  //Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors6.getTempCByIndex(0));
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL6, sensors6.getTempFByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL1)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL1, analogRead(SENSOR_PIN0));
//This function is called at intervals to send sensor datato Cayenne.
CAYENNE_OUT(VIRTUAL_CHANNEL2)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL2, analogRead(SENSOR_PIN1));
CAYENNE_OUT(VIRTUAL_CHANNEL3)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL3, analogRead(SENSOR_PIN2));
CAYENNE_OUT(VIRTUAL_CHANNEL4)
   Cayenne.virtualWrite(VIRTUAL_CHANNEL4, analogRead(SENSOR_PIN3));
did you look over my code still needing gauges with variables and color ranges have not heard back
in your change this :
to
Cayenne.virtualWrite(VIRTUAL_CHANNEL1, analogRead(SENSOR_PIN0), "analog_sensor", "null");
similarly do for others.
