Data feed
I am trying to set up data routing from the IoT-X stream platform using the link “https://lora.mydevices.com/v1/networks/stream/uplink” but I keep getting this message “Failure to add feed, please try again later”. Is it possible that this link is longer valid? or what could the problem be?
Hi @asset.tracking,
Everything should be working on our end.
Can you try contacting your Stream technical contact & see if there’s any issues on their side?
Thanks.
-Jesse
i figured it out. just modify “v” in the link to “v1.1”
Hi @asset.tracking,
Glad to hear you resolved it.
Just to clarify, you changed the URL from
to
https://lora.mydevices.com/v1.1/networks/stream/uplink
-Jesse
yes
I think the document provided is just not to date
Is this our document @asset.tracking?
