I have created a trigger for an output widget, so every time it goes online to trigger a notification. The problem is that the output only change state for about 1 second and the cayenne is no capable of triggering so fast. Any way to work around??
I’m assuming it’s due to the driver they are using for the GPIO. In WebIOPi there was no edge detection and you had to rely on running your loops fast enough to detect your events. Running your loop every 0.1 seconds pretty much ensured you would detect your event but also killed your pi to the point that you couldn’t do anything else on it.
