Device missing from iOS app
All my devices have disappeared from iOS app but populated on browser but non responsive . iOS app appears to be logged in and is asking to add devices.
William
same problem IOS iPhone 7 plus App raspberry 3
Try uninstalling the app, reinstall and sign in. This fixed it for me.
Worked for me too. I also have the 7 plus.
it doesn’t work
@adam any ideas?
I don’t have an iPhone to test it on. My only suggestion is to double check that you are logged in to the correct account on your iPhone.
@dirk1, do you mind to share your account credentials via private message so I can reproduce and investigate on our end?
