Device Offline (even after restart remains offline)
    Arduino UNO + W5100
    Web
    New project, 3 widgets (generic actuators), simple sketch, works for a while the first time, then goes offline, restart does not solve this, actuators do not work. Realise simular problems are allready described,
Another simular project (on my own account) just keep on working. so question how to check if you are offline because your banned due to creating too much traffic; not expecting this sketch is doing this but it is possible I am loosing connection because I am not returning fast enough back to the loop but on the other hand I tested this already a couple of times without any problems.
PS I am working on a new account for a new cayennne member; so i want to start with a working environment :smiley:
Sketch looks like:
Cayenne Ethernet Example
This sketch connects to the Cayenne server using an Arduino Ethernet Shield W5100
Steps:
  • RemoteSwitch library v2.3.0 (20121229) made by Randy Simons http://randysimons.nl/
  • License: GPLv3. See license.txt
#include <CayenneEthernet.h>
char token[] = “xxxxxx”;
#include <RemoteTransmitter.h>
KaKuTransmitter kaKuTransmitter(7); //data-pin 433 on pin 7
Serial.begin(115200);
Cayenne.begin(token);
CAYENNE_IN(V1) // KaKu B 1
kaKuTransmitter.sendSignal(‘B’,1, getValue.asInt());
CAYENNE_IN(V2) // KaKu B 2
kaKuTransmitter.sendSignal(‘B’,2, getValue.asInt());
CAYENNE_IN(V3) // KaKu B 3
kaKuTransmitter.sendSignal(‘B’,3, getValue.asInt());
@wj4me uncomment #define CAYENNE_DEBUG and check serial monitor for the error.
The LOG looks like this, the"["is repeated…
[0] MAC: FE-D9-E9-A5-D4-E4
[0] Getting IP...
[1613] My IP: 192.168.0.106
[5001] state 0, tconn 0
[5001] Connecting to arduino.mydevices.com:[0] MAC: FE-D9-E9-A5-D4-E4
[1] Getting IP...
[1614] My IP: 192.168.0.106
[5001] Connecting to arduino.mydevices.com:8442
[37224] Connect failure
[37224] state 0, tconn 0
[37225] Connecting to arduino.mydevices.com:8442
[37[0] MAC: FE-D9-E9-A5-D4-E4
[1] Getting IP...
[5066] Connect failure
[10002] Connecting to arduino.mydevices.com:8442
[10171] Connect success
[10172] <msg 2,1,10
<udwr7nnfnv
[10173] state 0, tconn 1
[10211] Login timeout
[0[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[
BTW This is the first time I am using this library, running without this library solves the problem but ping is low
[0] Getting IP...
[10277] Connecting to arduino.mydevices.com:8442
[10806] Ready (ping: 154ms).
@shramiksalgaonkar did some test with another Arduino+W5100 combination and it seems problems are caused by the hardware. Thanks for your reaction to the problem, sorry for the trouble.
Happy that you solve the problem. What was the exact problem in the hardware ? Did you manage to find it ?
Should practice on my solder skills; in this case attaching an antenna to the 433 sensor (will revert next time to the 17cm wire)
Get some flux gel. It make it very simple :wink:
