DHCP error
All worked well with arduino
i have more sckeches tried
upload this via cayenne procedure this is working
but i cannot get the right value for the sensors?
Dick
I’m not clear on what your problem is, can you explain a bit more? And the code you are using is always helpful too.
Ok
thanks
It is not DHCP but
the data,thaty i need to get thegood information for my temperature
It is an bmp180 with i2c sda/scl 0n the pins on my arduino
I think Pressure is “all right” but the temp is very strange.
Perhaps you know the answer
Dick
What do you mean by strange? Please check if you are sending Celsius or Fahrenheit?
