I have been using the same Pi for this project but I went ahead and removed the temp/humidity device on my dashboard. I added the new device ID to my code and its online consistently but no gauges on my dashboard
Youâll have to put the new credentials in your script as well (client ID)
I updated the Client ID in the tempsensor.py file is that what your referring to ?
Yes. I believe the username/password stays the same, but double check those as well.
Can you post the code you are using with the credentials taken out?
import time
import sys
import Adafruit_DHT
time.sleep(30) #Sleep to allow wireless to connect before starting MQTT
username = " "
password = " "
clientid = " "
mqttc = mqtt.Client(client_id=clientid)
mqttc.username_pw_set(username, password=password)
mqttc.loop_start()
topic_dht22_temp = "v1/" + username + "/things/" + clientid + "/data/3"
topic_dht22_humidity = "v1/" + username + "/things/" + clientid + "/data/4"
while True:
try:
humidity22, temp22 = Adafruit_DHT.read_retry(22, 4) #22 is the sensor type, 4 is the GPIO pin number (not physical pin number)
if temp22 is not None:
temp22 = "temp,c=" + str(temp22)
mqttc.publish(topic_dht22_temp, payload=temp22, retain=True)
if humidity22 is not None:
humidity22 = "rel_hum,p=" + str(humidity22)
mqttc.publish(topic_dht22_humidity, payload=humidity22, retain=True)
time.sleep(5)
mqttc.disconnect()
sys.exit()
Thanks, just wanted to make sure there wereât any errors there and there are not (that I saw). If you run the script below in a terminal with python (filename).py are you getting any errors? What is the connection status code?
import time
import sys
import Adafruit_DHT
#time.sleep(30) #Sleep to allow wireless to connect before starting MQTT
username = " "
password = " "
clientid = " "
def on_connect(client, userdata, flags, rc):
print("Connected with result code "+str(rc))
mqttc.on_connect = on_connect
mqttc.loop_start()
while True:
try:
time.sleep(5)
mqttc.disconnect()
When I initially got it working I used âpython2 /home/pi/python/tempsensor.pyâ I am not sure how to check the connection status code?
When I try running with python 3 I get this:
pi@raspberrypi:~ $ python3 /home/pi/python/tempsensor.py
File â/home/pi/python/tempsensor.pyâ, line 4, in
import Adafruit_DHT
ImportError: No module named âAdafruit_DHTâ
I added a print statement to the code, it will just print it out when it connects. Looks like you donât have the proper libraries installed under python3 just just use python 2. Save this file to /home/pi/python/test.py and then run it with python2 /home/pi/python/test.py
I copied the code from tempsensor.py to /home/pi/python/test.py and used âpython2 /home/pi/python/test.pyâ
Why am I getting the error message below?
pi @ raspberrypi: ~ $ sudo pip install paho-mqtt
sudo: pip: command not found
Just means you donât have pip installed. Install with sudo apt-get install pip
Thanks but now he has another problem!
pi@raspberrypi:~ $ sudo apt-get install pip
Reading package lists⌠Done
Building dependency tree
Reading state information⌠Done
E: Unable to locate package pip
Sorry, itâs python-pip. Try:
sudo apt-get install python-pip
Thanks it works. How pleace i a page into cd /home/pi/python/ white the name tempsensor.py
it says
pi@raspberrypi:~ $ cd /home/pi/python/
-bash: cd: /home/pi/python/: No such file or directory
Try using the command below, then cd to it.
mkdir -p /home/pi/python/
