can you share a screenshot of the command terminal with the error.
Use this to edit the file:
sudo nano /etc/myDevices/plugins/cayenne-plugin-dht
Yes, now I can modify the .plugin
But when I restart it, I donât get any new sensor in my cayenne dashboard
Do you have the Pi Agent installed?
I create an acount, how can it be easy?
once restart, enter tail -f /var/log/myDevices/cayenne.log
command and share the log here.
pi@SergiOlas:~ $ sudo service myDevices restart
pi@SergiOlas:~ $ tail -f /var/log/myDevices/cayenne.log
2019-03-14 11:53:38 - myDevices - INFO - DigitalActuator - RelaySwitch wnMKKvxLLon8Frr added
2019-03-14 11:53:38 - myDevices - INFO - Loading plugin: /etc/myDevices/plugins/cayenne-plugin-dht/cayenne_dht.plugin
2019-03-14 11:53:38 - myDevices - INFO - Sections: [âDHT Temperatureâ, âDHT Humidityâ]
2019-03-14 11:53:38 - myDevices - INFO - Creating instance of CayenneDHT for DHT Temperature
2019-03-14 11:53:38 - myDevices - INFO - Loaded sections: [âDHT Temperatureâ, âDHT Humidityâ]
2019-03-14 11:53:38 - myDevices - INFO - Enabled plugins: dict_keys([âcayenne_dht:1â, âcayenne_dht:0â])
2019-03-14 11:53:38 - myDevices - INFO - Executing regular download test for network speed
2019-03-14 11:53:38 - myDevices - INFO - Send system info: [{âsys:os:nameâ: âraspbianâ}, {âsys:os:versionâ: â9â}, {âagent:versionâ: â2.0.3.275â}, {âsys:pwr:resetâ: 0}, {âsys:pwr:haltâ: 0}, {âsys:i2câ: 1}, {âsys:devicetreeâ: 1}, {âsys:uartâ: 0}, {âsys:spiâ: 1}, {âsys:1wireâ: 1}]
2019-03-14 11:53:39 - myDevices - INFO - Sensors info: [{âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 1, ânameâ: 'IluminaciĂłn ', âchannelâ: âdev:24fd1268fc3246dâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 1, ânameâ: âRelay Switchâ, âchannelâ: âdev:42f6adb89eea436â}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 1, ânameâ: âTemperaturaâ, âchannelâ: âdev:4afe33e8979c472â}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 1, ânameâ: 'Calcio ', âchannelâ: âdev:84f46c8b6ec54dbâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âTemperatura Terrarioâ, âchannelâ: âdev:9xFMxytKGFLqFsIâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âCalcio Terrarioâ, âchannelâ: âdev:FIp88tMEKnytqEpâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âCalcio Terrarioâ, âchannelâ: âdev:HE0wtuIxEtxLKzCâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âIluminaciĂłn terrarioâ, âchannelâ: âdev:JL0K9zIvKnp7LJzâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âTemperatura Terrarioâ, âchannelâ: âdev:LsI2DMGLtCxpszyâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âCalcio Tempaturaâ, âchannelâ: âdev:qpsDwvCqMInEJvtâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âTemperatura Terrarioâ, âchannelâ: âdev:s94GsLMsICtwIMJâ}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âCalcio Terrarioâ, âchannelâ: âdev:ursHIDqEEyHv6r9â}, {âtypeâ: âdigital_actuatorâ, âunitâ: âdâ, âvalueâ: 0, ânameâ: âCalcio Terrarioâ, âchannelâ: âdev:wnMKKvxLLon8Frrâ}]
2019-03-14 11:53:41 - myDevices - INFO - Send changed data: [{âsys:cpu;loadâ: 21.6}, {âsys:cpu;tempâ: 47.236}, {âsys:ram;usageâ: 219811840}, {âsys:storage:/;usageâ: 4789497856}, {âsys:net;ipâ: â192.168.1.33â}, {âdev:24fd1268fc3246dâ: 1}, {âdev:42f6adb89eea436â: 1}, {âdev:4afe33e8979c472â: 1}, {âdev:84f46c8b6ec54dbâ: 1}, {âdev:9xFMxytKGFLqFsIâ: 0}, {âdev:FIp88tMEKnytqEpâ: 0}, {âdev:HE0wtuIxEtxLKzCâ: 0}, {âdev:JL0K9zIvKnp7LJzâ: 0}, {âdev:LsI2DMGLtCxpszyâ: 0}, {âdev:qpsDwvCqMInEJvtâ: 0}, {âdev:s94GsLMsICtwIMJâ: 0}, {âdev:ursHIDqEEyHv6r9â: 0}, {âdev:wnMKKvxLLon8Frrâ: 0}] + sys:gpio
After this. can you add more lines.
I donât understand U
can you share more lines from the log output?
I send all the lines of the terminal
it should continue adding more line as new data is send.
I let open the terminal, and it donât send nothing else, I will try again
Sorry, I get frezze on the remote viewer
This are the more lines:
2019-03-14 12:00:20 - myDevices - INFO - DigitalActuator - RelaySwitch wnMKKvxLLon8Frr added
2019-03-14 12:00:21 - myDevices - INFO - Loading plugin: /etc/myDevices/plugins/cayenne-plugin-dht/cayenne_dht.plugin
2019-03-14 12:00:21 - myDevices - INFO - Sections: ['DHT Temperature', 'DHT Humidity']
2019-03-14 12:00:21 - myDevices - INFO - Creating instance of CayenneDHT for DHT Temperature
2019-03-14 12:00:21 - myDevices - INFO - Loaded sections: ['DHT Temperature', 'DHT Humidity']
2019-03-14 12:00:21 - myDevices - INFO - Enabled plugins: dict_keys(['cayenne_dht:0', 'cayenne_dht:1'])
2019-03-14 12:00:21 - myDevices - INFO - Send system info: [{'sys:os:name': 'raspbian'}, {'sys:os:version': '9'}, {'agent:version': '2.0.3.275'}, {'sys:pwr:reset': 0}, {'sys:pwr:halt': 0}, {'sys:i2c': 1}, {'sys:spi': 1}, {'sys:1wire': 1}, {'sys:devicetree': 1}, {'sys:uart': 0}]
2019-03-14 12:00:21 - myDevices - INFO - Executing regular download test for network speed
2019-03-14 12:00:22 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:00:24 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 25.3}, {'sys:cpu;temp': 47.774}, {'sys:ram;usage': 219979776}, {'sys:storage:/;usage': 4789624832}, {'sys:net;ip': '192.168.1.33'}, {'dev:24fd1268fc3246d': 1}, {'dev:42f6adb89eea436': 1}, {'dev:4afe33e8979c472': 1}, {'dev:84f46c8b6ec54db': 1}, {'dev:9xFMxytKGFLqFsI': 0}, {'dev:FIp88tMEKnytqEp': 0}, {'dev:HE0wtuIxEtxLKzC': 0}, {'dev:JL0K9zIvKnp7LJz': 0}, {'dev:LsI2DMGLtCxpszy': 0}, {'dev:qpsDwvCqMInEJvt': 0}, {'dev:s94GsLMsICtwIMJ': 0}, {'dev:ursHIDqEEyHv6r9': 0}, {'dev:wnMKKvxLLon8Frr': 0}] + sys:gpio
2019-03-14 12:00:37 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:00:38 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 0.5}, {'sys:cpu;temp': 46.16}, {'sys:ram;usage': 221061120}, {'sys:storage:/;usage': 4789641216}, {'sys:net;speedtest': 0.979763475299428}]
2019-03-14 12:00:52 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:00:53 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 1.3}, {'sys:cpu;temp': 45.084}, {'sys:ram;usage': 221036544}, {'sys:storage:/;usage': 4789645312}]
2019-03-14 12:01:07 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:01:08 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 7.9}, {'sys:cpu;temp': 46.698}, {'sys:ram;usage': 221392896}, {'sys:storage:/;usage': 4789657600}]
2019-03-14 12:01:22 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:01:24 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 36.0}, {'sys:cpu;temp': 47.236}, {'sys:ram;usage': 222265344}, {'sys:storage:/;usage': 4789657600}, {'sys:net;ip': '192.168.1.33'}, {'sys:net;speedtest': 0.979763475299428}, {'dev:24fd1268fc3246d': 1}, {'dev:42f6adb89eea436': 1}, {'dev:4afe33e8979c472': 1}, {'dev:84f46c8b6ec54db': 1}, {'dev:9xFMxytKGFLqFsI': 0}, {'dev:FIp88tMEKnytqEp': 0}, {'dev:HE0wtuIxEtxLKzC': 0}, {'dev:JL0K9zIvKnp7LJz': 0}, {'dev:LsI2DMGLtCxpszy': 0}, {'dev:qpsDwvCqMInEJvt': 0}, {'dev:s94GsLMsICtwIMJ': 0}, {'dev:ursHIDqEEyHv6r9': 0}, {'dev:wnMKKvxLLon8Frr': 0}] + sys:gpio
2019-03-14 12:01:37 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:01:38 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 0.0}, {'sys:cpu;temp': 46.16}, {'sys:ram;usage': 221548544}, {'sys:storage:/;usage': 4789669888}]
2019-03-14 12:01:52 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:01:54 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 6.5}, {'sys:cpu;temp': 45.084}, {'sys:ram;usage': 221683712}]
2019-03-14 12:02:07 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:02:09 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 42.1}, {'sys:cpu;temp': 47.774}, {'sys:ram;usage': 221655040}, {'sys:storage:/;usage': 4789678080}]
2019-03-14 12:02:22 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:02:23 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 0.0}, {'sys:cpu;temp': 45.622}, {'sys:ram;usage': 222248960}, {'sys:storage:/;usage': 4789682176}, {'sys:net;ip': '192.168.1.33'}, {'sys:net;speedtest': 0.979763475299428}, {'dev:24fd1268fc3246d': 1}, {'dev:42f6adb89eea436': 1}, {'dev:4afe33e8979c472': 1}, {'dev:84f46c8b6ec54db': 1}, {'dev:9xFMxytKGFLqFsI': 0}, {'dev:FIp88tMEKnytqEp': 0}, {'dev:HE0wtuIxEtxLKzC': 0}, {'dev:JL0K9zIvKnp7LJz': 0}, {'dev:LsI2DMGLtCxpszy': 0}, {'dev:qpsDwvCqMInEJvt': 0}, {'dev:s94GsLMsICtwIMJ': 0}, {'dev:ursHIDqEEyHv6r9': 0}, {'dev:wnMKKvxLLon8Frr': 0}] + sys:gpio
2019-03-14 12:02:37 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:02:39 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 6.8}, {'sys:cpu;temp': 46.16}, {'sys:ram;usage': 221597696}, {'sys:storage:/;usage': 4789686272}]
2019-03-14 12:02:51 - myDevices - INFO - Disconnected with result code 1
2019-03-14 12:02:51 - myDevices - INFO - WriterThread mqttClient not connected
2019-03-14 12:02:52 - myDevices - INFO - WriterThread mqttClient not connected
2019-03-14 12:02:52 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:02:53 - myDevices - INFO - WriterThread mqttClient not connected
2019-03-14 12:02:53 - myDevices - INFO - Connected with result code 0
2019-03-14 12:02:53 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 21.6}, {'sys:cpu;temp': 47.236}, {'sys:ram;usage': 221663232}, {'sys:storage:/;usage': 4789698560}]
2019-03-14 12:03:07 - myDevices - INFO - Sensors info: [{'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn ', 'channel': 'dev:24fd1268fc3246d'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Relay Switch', 'channel': 'dev:42f6adb89eea436'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura', 'channel': 'dev:4afe33e8979c472'}, {'value': 1, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio ', 'channel': 'dev:84f46c8b6ec54db'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:9xFMxytKGFLqFsI'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:FIp88tMEKnytqEp'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:HE0wtuIxEtxLKzC'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'IluminaciĂłn terrario', 'channel': 'dev:JL0K9zIvKnp7LJz'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:LsI2DMGLtCxpszy'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Tempatura', 'channel': 'dev:qpsDwvCqMInEJvt'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Temperatura Terrario', 'channel': 'dev:s94GsLMsICtwIMJ'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:ursHIDqEEyHv6r9'}, {'value': 0, 'unit': 'd', 'type': 'digital_actuator', 'name': 'Calcio Terrario', 'channel': 'dev:wnMKKvxLLon8Frr'}]
2019-03-14 12:03:09 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 1.0}, {'sys:cpu;temp': 46.16}, {'sys:ram;usage': 221442048}, {'sys:storage:/;usage': 4789702656}]
the DHT plugin is loaded properly. have you connected the DHT sensor to correct pin number?
Yes, I buy it with the electronic and the resistor included so I put it in the + in the -, and in the GPIO 5. Instead of the not correct reading of the sensor, it have to create the widget, no?
can you delete your device and start new by adding a new device again?
