Dht11 interface with cayenne
im new in cayenne and arduino i started building my main project with cayenne but i have no idea to interface dht11 sensor with cayenne im using arduino mega
Hi @mithun7somaj,
Search the forum for DHT11. You should find what you are looking for.
@mithun7somaj agree with @kreggly, lots of DHT11 code is posted, just need to pick out what works best with project, let us know how that goes, or if you need further help, thanks!
im usng seriak mode to connect to cayenne can you help me with the code for dht11
I USED THIS CODEDHT_Cay.txt (3.2 KB)
BUT IT SHOWS ERROR CAN U HELP ME WITH THIS PLEASE
Arduino: 1.8.0 (Windows 10), Board: “Arduino/Genuino Uno”
In file included from C:\Users\MiThUn\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp:22:0:
C:\Users\MiThUn\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
"Show verbose output during compilation"
option enabled in File -> Preferences.
Hi @mithun7somaj,
If you use that DHT library, you need to also install the Adafruit Sensor Library:
Also, reviewing your code, you should not use a 10 second delay in the main loop as Cayenne.Run() is what processes all the messages.
Try this instead:
