DHT11, LInknode D1, Random Failed to read
I am using a Linknode D1 and have no problems when running the DHT Tester sketch.
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include “DHT.h”
#define DHTPIN D8 // what digital pin we’re connected to
// Uncomment whatever type you’re using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
Serial.println(“DHT11 test!”);
dht.begin();
// Wait a few seconds between measurements.
delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds ‘old’ (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(“Humidity: “);
Serial.print(h);
Serial.print(” %\t”);
Serial.print(“Temperature: “);
Serial.print(f);
Serial.print(” *F\t”);
Serial.print(“Heat index: “);
Serial.print(hif);
Serial.println(” *F”);
However when I run the following:
Cayenne ESP8266 WiFi Example
#include <CayenneESP8266WiFi.h>
#include “DHT.h”
#include “CayenneDefines.h”
char token[] = “xxxx”;
char ssid[] = “xxxx”;
char password[] = “xxxx”;
delay(3000);
if (isnan(h) || isnan(f)) {
return;
Serial.print(h);
Serial.print(f);
Serial.println(” *F\t”);
// These functions are called when the Cayenne widget requests data for the Virtual Pin.
CAYENNE_OUT(V0)
Cayenne.virtualWrite(V0, dht.readTemperature(true));
CAYENNE_OUT(V1)
Cayenne.virtualWrite(V1, dht.readHumidity());
Most of the time I get the “Failed to read from DHT sensor!” error.
Please suggest how I can fix the inconsistent error.
Thanks!
give this a try. DHT11/DHT22 - temperature and humidity sensor
