I’m not sure what to say. I’m using the same code with a NodeMCU and it works. According to your output yours does too. Have you looked at the graph view for the widgets? Here is a screen shot of mine (the straight line is when my battery died and forgot to replace it)
I just changed the setting to sleep at one minute but in the console is still the same information to know the anomaly of the last line
Implementation of the code (adam) at 1h15 since no new value and the anomaly at the bottom of the console serie.
No new values? The graph is changing, what are you expecting to see?
ERROR into the serial console
The graph changes until 1:15 because I did not put in the code the sleep function
CODE SLEEPING FUNCTION after 1h15
#define CAYENNE_DEBUG
#define DHTTYPE DHT22
#define DHTPIN 4
#include <DHT.h>
char ssid[] = "XXX";
char wifiPassword[] = "XXX";
char username[] = "XXX";
char password[] = "XXX";
char clientID[] = "XXX";
//Variables for DHT11 values
float h, t, hif;
//Time to sleep - 10 minutes - delete a zero to set to 1 minute
int SleepTime = 60000000;
//Values sent/error booleans
bool CayenneSent = false;
bool ReadError = false;
DHT dht(DHTPIN, DHTTYPE);
Serial.println("Setup");
ReadError = true;
//Run Cayenne Functions
//Only check values if there is a ReadError
if (ReadError){
ReadError = false;
//Check if read failed and try until success
int WhileLoops = 0;
do {
WhileLoops++;
//We can't go too long without calling Cayenne.loop() so exit this loop after 2 seconds and set an error flag
if (WhileLoops >= 4){
Serial.println("Sensor Read Error");
ReadError = true;
break;
//Read temperature as Celsius
t = dht.readTemperature();
//Read humidity (percent)
h = dht.readHumidity();
//Calculate Heat Index as Celsius
hif = dht.computeHeatIndex(t, h);
delay(500);
} while (isnan(t) || isnan(h));
Serial.print("Humidity: ");
Serial.println(h);
Serial.print("Temperature (c): ");
Serial.println(t);
Serial.print("Heat Index (c): ");
Serial.println(hif);
else {
//Check if we sent all values and sleep for 10 minutes if we did
if (CayenneSent){
Serial.println("Sent all values - sleeping");
delay(100);
ESP.deepSleep(SleepTime, WAKE_RF_DEFAULT);
delay(100);
CAYENNE_OUT_DEFAULT()
//Check if there was a read error and skip sending values if there is
if (!ReadError){
//Send Values
Cayenne.virtualWrite(0, h, "rel_hum", "p");
Cayenne.virtualWrite(1, t, "temp", "c");
Cayenne.virtualWrite(2, hif, "temp", "c");
//Set CayenneSent to true so we know when to sleep
CayenneSent = true;
CODE BEFORE 1H15 without sleeping function
//#define CAYENNE_DEBUG
#define DHTPIN 4
#include <DHT.h>
//Variables for DHT22 values
float h, t, hif;
delay(500);
Serial.println(h);
Serial.println(t);
delay(5000);
Use my original code and modify this line:
This will sleep for 1 minute and will be easier for you to see the values on the dashboard. After you upload the new code to the device watch your dashboard. If you haven’t already, make the widgets permanent with the green +. Let it run for a minimum of 15 minutes then come back and check your graph again and post a screen shot of it.
As requested I changed the code hereof below the detail.
I will wait 15 to 20 minutes and make the screenshot
float h, t, hif;
I start my device at 14h46mn20s
With this code
#define DHTPIN 4
#include <DHT.h>
char ssid = “XXX”;
char wifiPassword = “XXX”;
char username = “XXX”;
char password = “XXX”;
char clientID = “XXX”;
float h, t, hif;
int SleepTime = 600000000;
Serial.println(“Setup”);
ReadError = true;
if (ReadError){
ReadError = false;
int WhileLoops = 0;
do {
WhileLoops++;
//We can’t go too long without calling Cayenne.loop() so exit this loop after 2 seconds and set an error flag
Serial.println(“Sensor Read Error”);
ReadError = true;
break;
delay(500);
Serial.println(h);
Serial.println(t);
else {
if (CayenneSent){
Serial.println(“Sent all values - sleeping”);
delay(100);
delay(100);
if (!ReadError){
//Send Values
Cayenne.virtualWrite(0, h, “rel_hum”, “p”);
Cayenne.virtualWrite(1, t, “temp”, “c”);
Cayenne.virtualWrite(2, hif, “temp”, “c”);
CayenneSent = true;
In my serial console
in my cayenne interface
im wait 15 mn and im post the message
What about the graph?
can you set the graph to minutes.
Looks like graphs were having issues, I checked mine at the same time and also had no data. Should work now (does for me anyway). Also, did you leave the device on? if it’s not sending data of course there will not be anything to show for the last hour.
I have not cut anything since 14h46
So what does your hour/minute graph show now?
It looks like there are some issues right now. Sorry for going back and forth on this, but I would suggest waiting until everything is back up and running correctly again before trying anything else.
