Dht22 / cayenne
#61
Noted. I wait and stay at your listening on the post
#62
for information i have nothing since 13h15
#63
At 13h15 i change the code with the sleep function. Before 13h15 i don’t have the sleep function
#64
In a PM @shramiksalgaonkar brought up a good point. Is your device waking up? You need to connect pin 16 to RST. Have a read through my whole post to make sure you haven’t missed anything there Battery Powered ESP8266 Temperature/Humidity Monitor with DHT11
#65
Everything seems fine on my end now. Are you seeing any difference?
#67
This morning everything seems ok on my side I have correct values ​​in my cayenne interface.
I still have two questions:
1 °) I would like to know the state of my batteries by sending on the interface cayenne the remaining capacity.
2 °) I have a soil moisture sensor but I do not know how to integrate it in the DHT22 code.
Thanking you in advance.
#68
hi, had you connected pin 16 to reset pin?
#69
Yes I had connected the PIN 16.
I will try to follow the post but I am French and it is not easy for the translation.
Thanks again.
#70
can you share pic of your devices with pin 16 connected to reset and dht.
#71
#72
look good now. on you give a try with @adam sleeping code and it should be working. it looked like previously you had not connected the pin 16 to reset with blue wire.
#73
@terreemer did you test it out?
#74
@shramiksalgaonkar looks like he’s good with the DHT part.
@terreemer what kind/voltage of battery are you trying to monitor?
