Does it support ENC28J60 module?
  • Arduino MEGA, ENC28J60 module
  • Web
  • I am trying to use this module with arduino MEGA, it is not shield but has the same chip as I know, this module is so widely used is there any way to use this platform with this module if not can be added to wish list?
Welcome to Cayenne!
Have a look at this thread. I got it working with the code posted there.
The connection on MEGA is like this? (As Ethercard custom library said.)
VCC - 3.3V
GND - GND
SCK - Pin 52
SO - Pin 50
SI - Pin 51
CS - Pin 53 # Selectable with the ether.begin() function
You can just use the same pins that are in the post.
  • Wire it up:
  • VCC – 5V
  • GND – GND
  • CS – D10
  • SI – D11
  • SCK – D13
  • SO – D12
  • INT – D2
There are not such pins on Arduino MEGA
Those pins exist on all Arduino boards. Here they are on the mega (pink numbers):
It works for mega!!
 * For this example you need UIPEthernet library:
 *   https://github.com/ntruchsess/arduino_uip
VCC - 3.3V
GND - GND
SCK - Pin 52
SO - Pin 50
SI - Pin 51
CS - Pin 53
#include <CayenneDefines.h>
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
#include <CayenneEthernetClient.h>
char token[] = "TOKEN"; //NOT MY TOKEN
  Cayenne.begin(token);
How to stop Cayenne.run() running continuously?
This module is going too hot 45-55C. How can I put this module on sleep mode to increase the lifespan like here with the old EtherShield library? (Should I make new thread?)
