Hi guys i have 2 project on Cayenne and right now i have a issue. Can you talk about Cayenne.begin and Cayenne.loop parameters? I tried to official cayenne code about thermometer and lux values and its work very good but when i start to write a own code on void setup its not working i am just using pinMode command why it is not sending data?
Hi ozbayalperen1
Could you post your code
I cant share my all code because i can’t find to all part but i can share my code’s part and error. When i type this its work:
const int trigPin = 6;
const int echoPin = 7;
int duration;
int distance;
int sayi = 0;
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
lastMillis = millis();
Cayenne.virtualWrite(3, 13, TYPE_PROXIMITY, UNIT_CENTIMETER);
CAYENNE_IN_DEFAULT()
But if i type to pinmode command its not working like this:
int duration;
int distance;
int sayi = 0;
char ssid[] = "";
pinMode(trigPin,OUTPUT);
pinMode(ECHOPin,INPUT);
@ozbayalperen1 the problem is the pins which you have selected for trigger and echo. on esp8266 there are no GPIO 6 and 7. so changing them to 4 and 5 works.
I am using nodeMcu bruh.
I am using this one: GREATZT ESP8266 ESP 12 ESP12 WeMos D1 Mini modülü Wemos D1 Mini WiFi geliştirme kurulu mikro USB 3.3V dayalı ESP 8266EX 11 kazmak|Entegre Devreler| - AliExpress
No matter which variation you use, ESP8266 devices simply don’t have GPIO 6 or 7. D6 != GPIO6 and D7 != GPIO 7
Actually, the pinout was on the page you linked. D6 is GPIO 12 and D7 is GPIO 13. Replace the 6 and 7 with 12 and 13 and I think you will find it works.
@ozbayalperen1 for once replace your 6 and 7 pin to other pin like 12 and 13 . Give it a try and see if it works and then reply.
Thank you guys it is working
