Arduino Uno with W5100 ethernet shield
Web cayenne
I have errors when compiling for the DS18B20 temp sensor.
I have installed the cayenne library and got the arduino device added to the webinterface.
I also got the dallastemperature and the onewire library added.
but when trying to compile it says:
sketch_oct02a.cpp.o: I funktionen "_GLOBAL__sub_I_Blynk":
/usr/share/arduino/sketch_oct02a.ino:48: undefined reference to `OneWire::OneWire(unsigned char)'
DallaTemperature/DallasTemperature.cpp.o: I funktionen "DallasTemperature::setAlarmHandler(void (*)(unsigned char const*))":
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::crc8(unsigned char const*, unsigned char)'
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::reset_search()'
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::search(unsigned char*, bool)'
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::reset()'
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::select(unsigned char const*)'
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::write(unsigned char, unsigned char)'
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::read()'
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::read_bit()'
/home/thomas/sketchbook/libraries/DallaTemperature/DallasTemperature.cpp:804: undefined reference to `OneWire::skip()'
collect2: error: ld returned 1 exit status
the sketch im using is
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <EthernetServer.h>
#include <Dhcp.h>
#include <EthernetClient.h>
#include <Dns.h>
#include <util.h>
Cayenne DS18B20 Example
This sketch shows how to send temperature data to a DS18B20 Sensor in the Cayenne Dashboard.
Steps:
1. Install the OneWire library (http://www.pjrc.com/teensy/td_libs_OneWire.html) from the Arduino Library Manager.
2. Install the DallasTemperature library (http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library#Code.2FLibrary) from the Arduino Library Manager.
3. In the Cayenne Dashboard add a new DS18B20 widget.
4. Set the widget to Value Display.
5. Select Virtual Pins and a virtual pin number.
6. Set VIRTUAL_PIN to the pin number you selected.
7. Attach a DS18B20 to an digital pin on your Arduino.
Schematic:
[Ground] -- [DS18B20] -- [4.7k resistor] -- [5V]
|______________|
Digital Pin
8. Set the tmpPin variable to match the pin used to connect the DS18B20.
9. Set the token variable to match the Arduino token from the Dashboard.
10. Compile and upload this sketch.
11. Once the Arduino connects to the Dashboard it should automatically update the DS18B20 widget with data.
#include <OneWire.h>
#include <CayenneEthernet.h>
#define VIRTUAL_PIN V1
const int tmpPin = 2;
OneWire oneWire(tmpPin);
char token[] = "xxxxxx";
Cayenne.begin(token);
sensors.begin();
CAYENNE_OUT(VIRTUAL_PIN)
Cayenne.celsiusWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
