Ds18b20 + hcsr04 + nodemcu + cayenne
Hello everyone,
I encounter an error on my code following the addition of DS18B20 sensor to my project CAYENNE + NODEMCU + 2 HCSR04 sensors.
Both sensors work perfectly however I need to add 2 temperature sensors to my initial project.
Here is the code added that gives errors to the compilation
// 2 HCSR04 Pour la mesure de hauteur d’eau dans des cuves de 1000 litres.
#define CAYENNE_DEBUG
#include <ESP8266WiFi.h>
#include "CayenneDefines.h"
#include <OneWire.h>
#define VIRTUAL_PIN1 V1
#define VIRTUAL_PIN2 V2
const int tmpPin = 14;
OneWire oneWire(tmpPin);
//const int tmpPin1 = 1;
//OneWire oneWire1(tmpPin1);
//DallasTemperature sensors1(&oneWire1);
char ssid[] = "XXX";
char wifiPassword[] = "XXX";
char username[] = "XXX";
char password[] = "XXX";
char clientID[] = "XXX";
unsigned long lastMillis = 0;
unsigned long lastMillis2 = 0;
// defines pins numbers HCSR04 N°1
const int trigPin = 2;  //D4
const int echoPin = 0;  //D3
// defines pins numbers HCSR04 N°2
const int trigPin2 = 4;  //D2
const int echoPin2 = 5;  //D1
// defines variables HCSR04 N°1
long duration;
int distance;
int y;
// defines variables HCSR04 N°2
long duration2;
int distance2;
int y2;
  Serial.begin(9600); // Starts the serial communication
  sensors.begin();
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  pinMode(trigPin2, OUTPUT); // Sets the trigPin2 as an Output
  pinMode(echoPin2, INPUT); // Sets the echoPin2 as an Input
//HCSR04 N°1
  // Clears the trigPin
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin on HIGH state for 10 micro seconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculating the distance
  distance = ((duration * 0.034) / 2)-10;
  // Prints the distance on the Serial Monitor
  Serial.print("Distance: ");
  Serial.println(distance);
  y = map(distance, 95, 10, 0, 100);
  y = constrain(y, 0, 100);
  delay(5000);
    lastMillis = millis();
    //Cayenne.virtualWrite(10, 105-distance);
    //Cayenne.virtualWrite(11, y, "t1", "null");
    Cayenne.virtualWrite(1, y, "analog_sensor", "null");
//HCSR04 N°2
 // Clears the trigPin N°2
  digitalWrite(trigPin2, LOW);
  // Sets the trigPin N°2 on HIGH state for 10 micro seconds
  digitalWrite(trigPin2, HIGH);
  // Reads the echoPin N°2, returns the sound wave travel time in microseconds
  duration2 = pulseIn(echoPin2, HIGH);
  // Calculating the distance N°2
  distance2 = ((duration2 * 0.034) / 2)-10;
   // Prints the distance N°2 on the Serial Monitor
  Serial.print("Distance2: ");
  Serial.println(distance2);
  y2 = map(distance2, 95, 10, 0, 100);
  y2 = constrain(y2, 0, 100);
  delay(5000);
  if (millis() - lastMillis2 > 10000) {
    lastMillis2 = millis();
    //Cayenne.virtualWrite(20, 105-distance2);
    //Cayenne.virtualWrite(21, y2, "t1", "null");
    Cayenne.virtualWrite(2, y2, "analog_sensor", "null");
  // do something
CAYENNE_OUT(V1)
  //Cayenne.virtualWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
  Cayenne.virtualWrite(VIRTUAL_PIN1, sensors.getTempFByIndex(0));
CAYENNE_OUT(V2)
  Cayenne.virtualWrite(VIRTUAL_PIN2, sensors.getTempFByIndex(1));
CAYENNE_CONNECTED()
  CAYENNE_LOG("Connection established");
The error :
erreur
it’s smell like an acolade missing somewhere !!
I have made the syntax changes to your code but not tested it. and you should have continued on the previous topic only instead of creating a new one.
long duration;
int distance;
int y;
long duration2;
int distance2;
int y2;
  sensors.begin();
  //HCSR04 N°1
  distance = ((duration * 0.034) / 2) - 10;
  delay(5000);
  //HCSR04 N°2
  distance2 = ((duration2 * 0.034) / 2) - 10;
  delay(5000);
CAYENNE_OUT(V1)
CAYENNE_OUT(V2)
Thank’s for all. All is all right.
everything is working fine?
Hello shramiksalgaonkar,
Yes, everything is OK, I just added some delay (5000); because values were strange.
How can I close my two posts?
Thanks again for the time spent with me to help me.
I have to come back to the forum in a few days because I have problems with a raspberry PI3 and a motion sensor.
Vincent.
