DS18B20 Reading parasitic mode
Search returned null :slight_smile:
Is this mode working with Cayenne?
I made quick experiment with working DS code but no luck temp showing is tripeled, and reading looks like random.
From what I’m seeing parasitic mode causes more problems than it’s worth in most cases. Are you connecting with MQTT? If so can you share your code?
Parasitic works fine for me, its not usable where super speed readings are required other than that its ok.
I am not using mqtt, and the code is example from Arduino IDE modified for connecting standalone esp-01 to Cayenne. Connection part works like on my other devices but the code from example is not “happy” on this module. I will try to figure it out during next weekend.
