DS18B20 reads 33.8° constantly
Continuing the discussion from Arduino Uno + DS18B20 temp sensor:
@brewer06ky,
Welcome to the Cayenne Community! I hope you don’t mind I opened a new discussion for your challenge as the original one had been marked ‘helped’.
Could you provide a little more information- what hardware (RPi, Arduino, ethernet, wifi, etc.), any code you may be using, and photos and screen grabs are always helpful.
Again, welcome,
-Ian
Thanks Ian, I have to work 16 hours today I’ll get everything together in a day or so.
Take your time, be safe in what you do, and we’ll try to sort things out later.
-Ian
I got off this morning and went to hp load everything and I realize my problem. I changed VIRTUAL_PIN V1 to V5 and changed tmpPin = 2 to 5 as well. Then it started working when I moved the input to pin 5.
@brewer06ky
Great to hear!
It is amazing what you ‘see’ after taking a break from a problem.
May I mark this as helped, even though you did all the work?
-Ian
Plz. And thanks for your time. I’m sure I’ll have plenty of more questions soon.
