DS18B20 sensor problem
    Rpi3
    web and iOS
First I am have having trouble with the connection. Several times they show disconnected on the web browser or the temps read either 32 or nothing.
Secondly, the widget don’t stay as I set them up to read as a value and temp icon. Many times they have changed to line graphs(most populated as line graphs which I’ve never encountered before).
I thought perhaps I had wired them incorrectly and searched threads on here dealing with these sensors and it showed wiring only 1 resistor but as I found out there must be a resistor across each sensor or only 1 populates.
can yo post the code you are using.
hey there @shramik_salgaonkar:
I am using Rpi3 so no code. Seems the problem went away.
