Ds3231 temperature display in Cayenne
Using an ESP8266 (HUZZAH) with a DS3231 RTC. The temperature displays in the serial monitor but I’m unable to figure out how to get it to Cayenne. Tried every combination I could think of. Truly, I don’t have any idea of what I’m doing. Any pointers?
Thanks,
John
ERROR:
In function ‘void loop()’:
RTC_cayenne_min:93: error: cannot convert ‘RtcTemperature’ to ‘float’ in initialization
float currentTemp = (temp);
exit status 1
Relevant code:
RtcTemperature temp = Rtc.GetTemperature();
Serial.print(temp.AsFloat());
Serial.println(“C”);
Serial.println();
// My stuff:
//float currentTemp = (96); // Test: this creates temperature widget with 96 in it.
Cayenne.celsiusWrite(1, currentTemp);
Full Code:
//#define CAYENNE_DEBUG
#include <Wire.h> // must be included here so that Arduino library object file references work
#include <RtcDS3231.h>
RtcDS3231 Rtc(Wire);
Usual Login Stuff:
unsigned long lastMillis = 0;
Serial.print("compiled: ");
Serial.print(__DATE__);
Serial.println(__TIME__);
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
printDateTime(compiled);
Serial.println();
if (!Rtc.IsDateTimeValid())
    // Common Cuases:
    //    1) first time you ran and the device wasn't running yet
    //    2) the battery on the device is low or even missing
    Serial.println("RTC lost confidence in the DateTime!");
    // following line sets the RTC to the date & time this sketch was compiled
    // it will also reset the valid flag internally unless the Rtc device is
    // having an issue
    Rtc.SetDateTime(compiled);Rtc.Begin();
if (!Rtc.GetIsRunning())
    Serial.println("RTC was not actively running, starting now");
    Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
    Serial.println("RTC is older than compile time!  (Updating DateTime)");
else if (now > compiled)
    Serial.println("RTC is newer than compile time. (this is expected)");
else if (now == compiled)
    Serial.println("RTC is the same as compile time! (not expected but all is fine)");
// never assume the Rtc was last configured by you, so
// just clear them to your needed state
Rtc.Enable32kHzPin(false);
Rtc.SetSquareWavePin(DS3231SquareWavePin_ModeNone);
delay(15000);
// Common Cuases:
// 1) the battery on the device is low or even missing and the power line was disconnected
Serial.println(“RTC lost confidence in the DateTime!”);
printDateTime(now);
Serial.println();
Serial.println("C");
Serial.println();
// My stuff:
// float currentTemp = (96); // Test: this creates temperature widget with 96 in it.
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
        countof(datestring),
        PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
        dt.Month(),
        dt.Day(),
        dt.Year(),
        dt.Hour(),
        dt.Minute(),
        dt.Second() );
Serial.print(datestring);
Hi @margettepv,
Did you add a widget using virtual pin 1 to your Cayenne dashboard?
~Benny
Yup, got a widget as such. But I never got it to compile, except when using the test line.
John
try this code and see if it works for you.
// CONNECTIONS:
// DS3231 SDA --> SDA
// DS3231 SCL --> SCL
// DS3231 VCC --> 3.3v or 5v
// DS3231 GND --> GND
/* for software wire use below
#include <SoftwareWire.h>  // must be included here so that Arduino library object file references work
SoftwareWire myWire(SDA, SCL);
RtcDS3231<SoftwareWire> Rtc(myWire);
 for software wire use above */
/* for normal hardware wire use below */
RtcDS3231<TwoWire> Rtc(Wire);
/* for normal hardware wire use above */
char ssid[] = "ssid";
float x;
void setup ()
    Serial.begin(57600);
    //--------RTC SETUP ------------
    // if you are using ESP-01 then uncomment the line below to reset the pins to
    // the available pins for SDA, SCL
    // Wire.begin(0, 2); // due to limited pins, use pin 0 and 2 for SDA, SCL
    Rtc.Begin();
    Serial.println();
        // Common Cuases:
        // having an issue
    if (now < compiled)
void loop ()
    lastMillis = millis();
 Cayenne.celsiusWrite(1, x);
        // Common Cuases:
    printDateTime(now);
    Serial.println();
  temp.Print(Serial);
  // you may also get the temperature as a float and print it
    x = temp.AsFloatDegC();
            dt.Month(),
            dt.Day(),
            dt.Year(),
            dt.Hour(),
            dt.Minute(),
            dt.Second() );
Not there yet. Compile error:
Arduino: 1.8.5 (Linux), Board: “Adafruit HUZZAH ESP8266, 80 MHz, 4M (3M SPIFFS), v2 Prebuilt (MSS=536), Disabled, None, 115200”
/home/m/Arduino/sketch_feb16a/sketch_feb16a.ino: In function ‘void loop()’:
sketch_feb16a:122: error: ‘class RtcTemperature’ has no member named ‘Print’
temp.Print(Serial);
sketch_feb16a:124: error: ‘class RtcTemperature’ has no member named ‘AsFloatDegC’
exit status 1
Just to be clear, the code I posted was good other than where I tried to make it post to Cayenne.
Thanks shramiksalgaonkar.
John
