i AM TRYING TO BUILD a ENERGY MONITOR .
Does ANYONE Have experience using A CT SENSOR TO MEasure current. i hAVE WIRED IT UP AS CLOSE TO all the tutorials show. with the exception of a 33OHM RESISTOR TO THE RECOMMENDED 18OHM.
THE ISSUE I am hAVING IS THat when there is no current to meASURE I STILL GET a very smALL REading from controller. AND WHEN I DISCONNECT THE SENSOR IT STILL SHOWS UP. wHEN THERE IS a A LOAD IT appears to be working ok.
#include “EmonLib.h”
// Include Emon Library
EnergyMonitor emon1;
// Create an instance
emon1.current(1, 111.1); // Current: input pin, calibration.
double Irms = emon1.calcIrms(1480); // Calculate Irms only
Serial.print(Irms*230.0); // Apparent power
Serial.print(" ");
Serial.println(Irms); // Irms
