Error compiling for board arduino
combine two sketches (with help thanks) both sketches compile fine but new combined sketch i get error compiling for board arduino uno . The error message appears to have something to do with cayenne ethernet mqtt multiple libraries were found .
I will post error message and then my sketch below
Arduino: 1.8.3 (Windows 7), Board: “Arduino/Genuino Uno”
In file included from C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoDefines.h:128:0,
             from C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT\src/CayenneArduinoMQTTClient.h:21,
             from C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTEthernetClient.h:21,
             from C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTEthernetW5500.h:25,
             from C:\Users\Home Laptop\Documents\Arduino\xoxoxo\xoxoxo.ino\xoxoxo.ino.ino:6:
C:\Users\Home Laptop\Documents\Arduino\xoxoxo\xoxoxo.ino\xoxoxo.ino.ino: In function ‘void OutputHandler4(Request&)’:
C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT\src/CayenneHandlers.h:69:37: error: redefinition of ‘void OutputHandler4(Request&)’
#define CAYENNE_OUT_2(channel) void OutputHandler ## channel (Request& request)
C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT\src/CayenneHandlers.h:71:30: note: in expansion of macro ‘CAYENNE_OUT_2’
#define CAYENNE_OUT(channel) CAYENNE_OUT_2(channel)
C:\Users\Home Laptop\Documents\Arduino\xoxoxo\xoxoxo.ino\xoxoxo.ino.ino:86:1: note: in expansion of macro ‘CAYENNE_OUT’
CAYENNE_OUT(VIRTUAL_CHANNEL4)
C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT\src/CayenneHandlers.h:69:37: note: ‘void OutputHandler4(Request&)’ previously defined here
C:\Users\Home Laptop\Documents\Arduino\xoxoxo\xoxoxo.ino\xoxoxo.ino.ino:59:1: note: in expansion of macro ‘CAYENNE_OUT’
CAYENNE_OUT(VIRTUAL_CHANNEL6)
Multiple libraries were found for “CayenneMQTTEthernetW5500.h”
Used: C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT
Not used: C:\Users\Home Laptop\Documents\Arduino\libraries\Cayenne-MQTT-Arduino-master
exit status 1
Error compiling for board Arduino/Genuino Uno.
//#define CAYENNE_DEBUG
//#include <CayenneMQTTEthernet.h>
#include <CayenneMQTTEthernetW5500.h>
 #include <OneWire.h>
unsigned long lastMillis = 0;
#define SENSOR_PIN0 A0
#define VIRTUAL_CHANNEL1 1
#define SENSOR_PIN1 A1
#define VIRTUAL_CHANNEL2 2
#define SENSOR_PIN2 A2
#define VIRTUAL_CHANNEL3 3
#define SENSOR_PIN3 A3
#define VIRTUAL_CHANNEL4 4
#define VIRTUAL_CHANNEL5 5
#define VIRTUAL_CHANNEL6 4
const int tmpPin6 = 6;
const int tmpPin5 = 5;
OneWire oneWire6(tmpPin6);
OneWire oneWire5(tmpPin5 );
DallasTemperature sensors6(&oneWire6);
  sensors5.begin();
  sensors6.begin();
CAYENNE_OUT(VIRTUAL_CHANNEL5)
  //Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors5.getTempCByIndex(0));
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL5, sensors5.getTempFByIndex(0));
  sensors6.requestTemperatures();
  //Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors6.getTempCByIndex(0));
  Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL6, sensors6.getTempFByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL1)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL1, analogRead(SENSOR_PIN0));
//This function is called at intervals to send sensor datato Cayenne.
CAYENNE_OUT(VIRTUAL_CHANNEL2)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL2, analogRead(SENSOR_PIN1));
CAYENNE_OUT(VIRTUAL_CHANNEL3)
  Cayenne.virtualWrite(VIRTUAL_CHANNEL3, analogRead(SENSOR_PIN2));
   Cayenne.virtualWrite(VIRTUAL_CHANNEL4, analogRead(SENSOR_PIN3));
there is an bug in this. tagging @jcruz and @bestes for this.
I see a couple issues. One is that this line:
should be
#define VIRTUAL_CHANNEL6 6
otherwise it will conflict with the previously defined channel 4.
Also it appears you have two versions of the Cayenne MQTT library installed. One at C:\Users\Home Laptop\Documents\Arduino\libraries\CayenneMQTT that was probably installed via the Arduino Library Manager and one at C:\Users\Home Laptop\Documents\Arduino\libraries\Cayenne-MQTT-Arduino-master that was probably installed manually. This causes issues for the Arduino IDE so you should remove the Cayenne-MQTT-Arduino-master library folder then restart the Arduino IDE and try to compile the sketch again.
