Error: ESP8266_Lib.h:
Hi, I’m trying a long time ago how to connect my arduino mega 2560 with esp8266 and every time I try something new it always throws me the same error
I leave details of the error and the code that I am using.
#include <ESP8266_Lib.h>
#include <cayenneMQTTESP8266.h>
#define CAYENNE_DEBUG
//Coneccion a internet
char ssid[] = "";
char wifiPassword[] = "";
//Autentificacion chayanne
char username[] = ""
char password[] = ""
char clientID[] = ""
unsigned long lastmillis = 0;
  Cayenne.begin(username, password, cleintID, ssid, wifiPassword)
  cayenne.loop();
  //publica datos cada 10 segundos
    lastmillis = millis();
    //escribe datos en chayanne
    cayenne.virtualWrite( 0, lastmillis);
CAYENNE_IN_DEFAULT()
C:\Users\Snaab\Desktop\tesis\IDE\chayane\chayane.ino:2:25: fatal error: ESP8266_Lib.h: No such file or directory
compilation terminated.
exit status 1
Error compilando para la tarjeta Arduino/Genuino Mega or Mega 2560.
you are doing it wrong. follow this steps Cayenne-MQTT-Arduino/ESP8266Shield.ino at master · myDevicesIoT/Cayenne-MQTT-Arduino · GitHub
Use the program that you told me with the corresponding libraries, the problem of the library that attached me the things that I have to do with the problem. I also attached the error that came back out if you helped me please.
Opciones de compilación cambiadas, reconstruyendo todo
In file included from D:\tesis\IDE\prueba_33333333\prueba_33333333.ino:18:0:
C:\Users\Snaab\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTESP8266Shield.h:31:34: fatal error: ESP8266SerialLibrary.h: No such file or directory
#include “ESP8266SerialLibrary.h”
exit status 1
please follow the steps from the link i gave. step 1 is installing the library.
Search and download the Internet library and the problem persists. Could you send me the link to the bookstore that you tell me is missing please.
Steps:
  1. Install the ESP8266SerialLibrary.zip library via the Arduino IDE (Sketch->Include Library->Add .ZIP Library) from the Cayenne extras/libraries folder (e.g. My Documents\Arduino\libraries\CayenneMQTT\extras\libraries) to compile this example.
I already fix the problem of the bookstores but I get the image. Could you tell me how the pins of the esp8266 are connected to the ArduinoMega2560?
I have connected
vcc and ch_pd - 3.3v
gnd - gnd
rx - rx0 (arduino pin)
tx - tx1
It’s okay?
Captura
See if I’m connected to the internet and even then nothing happens.
Hi again, I’m trying to send analog data from 3 gas sensors (MQ2) but only get one. Previously I tried sending only one and if it worked, but when you add the other two and save the program, you only receive the data from one channel. I enclose the program I use and the photo of the widgets.
char ssid = “Aceituna”;
char wifiPassword = “vaquito123”;
char username = “50c54bf0-1b49-11e8-b42d-698bd45831f1”;
char password = “5c683ef173bb78d7829f2a96b938ff2c6614e345”;
char clientID = “415eee60-1f08-11e8-b42d-698bd45831f1”;
#define EspSerial Serial1
#define PinAna 0
#define VIRTUAL_CHANNEL 2
#define PinAna1 1
#define VIRTUAL_CHANNEL 4
#define PinAna2 2
#define VIRTUAL_CHANNEL 6
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(PinAna));
Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(PinAna1));
Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(PinAna2));
Is the logic of the program fine?
and another problem I have is that the sensor does not fall below this value
Is there a way to lower it to 0 or> 100?
I already fixed the problem so that I could read the other sensors, now I would like to know if I can leave the rods in 0 or in a lower number
