Error on Cayenne ESP8266 Code
Hi i wanna connect my generic ESP8266 Arduino UNO with Cayenne platform. I have a issue about libs. Cayenne have a too much libs on Arduino. Can you help me? My error on Arduino IDE :
Arduino:1.8.4 (Windows 10), Kart:“Arduino/Genuino Uno”
In file included from C:\Program Files (x86)\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:33:0,
             from C:\Users\mucittin\Documents\Arduino\libraries\Cayenne-MQTT-ESP8266-master\src/CayenneMQTTESP8266.h:21,
             from C:\Users\mucittin\AppData\Local\Temp\arduino_modified_sketch_864497\ESP8266.ino:6:
C:\Program Files (x86)\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:26:19: fatal error: queue.h: No such file or directory
#include <queue.h>
compilation terminated.
“CayenneMQTTESP8266.h” için birden fazla library bulundu
Kullanılıyor: C:\Users\mucittin\Documents\Arduino\libraries\Cayenne-MQTT-ESP8266-master
Kullanılmıyor: C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-ESP8266-master
exit status 1
Error compiling for board Arduino/Genuino Uno.
Thanks for help!
from there error it looks like you either have the wrong board selected or have not installed the ESP boards. Here are instructions on doing so.
I am just using Arduino Uno and ESP8266 i am not using nodemcu or other cards.
Ah, I see now. Follow this post here. Using an ESP8266 as a shield is still not officially supported.
Bumping this old thread to share that we’ve just provided support in our MQTT Arduino library for using ESP8266 as a shield :slight_smile: We’ve done basic testing and works well. Give it a try for your project and let us know how it works out for you !
