Error on New Library
Hi, thanks for new lib guys but i can’t verify this code:
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define EspSerial Serial1
ESP8266 wifi(&EspSerial);
  delay(10);
  EspSerial.begin(115200);
  delay(10);
CAYENNE_OUT_DEFAULT()
  Cayenne.celsiusWrite(1, 22.0);
  Cayenne.luxWrite(2, 700);
  Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
CAYENNE_IN_DEFAULT()
It is giving this error:
This example uses the Serial1 hardware serial pins available on the Mega. You can also try
Okay i will use in Mega. Thanks
you can also use uno but connect esp8266 with software serial.
