ESP-07S single relay
Hi Guys,
I’m having problems getting a single relay to operate. I have it wired up to GPIO4 but can’t get it to switch (and running on 5v)…
Here is my code (probably something simple!)
#define VIRTUAL_PIN 4
#define RELAY_DIGITAL_PIN 4
char ssid[] = “My SSID”;
char wifiPassword[] = “IEatChicken”;
char username[] = “asdfasfasfdsafd”;
char password[] = “asdfsafdsafdasf”;
char clientID[] = “asdfasfdsafdsafd”;
unsigned long lastMillis = 0;
pinMode(RELAY_DIGITAL_PIN, OUTPUT);
Serial.begin(115200);
CAYENNE_IN(VIRTUAL_PIN)
if (currentValue == 0) {
digitalWrite(RELAY_DIGITAL_PIN, HIGH);
} else {
digitalWrite(RELAY_DIGITAL_PIN, LOW);
lastMillis = millis();
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Thanks in advance!
Benny
Can you post a link to the relay and how you have it wired?
@bennyrut,
On some versions of the ESP-07, GPIO4 and GPIO5 labels are flipped.
I suggest you measure the outputs on GPIO4 and GPIO5 with a voltmeter to see if they toggle when you press the dashboard button, and adjust your circuit accordingly.
Hi Adam,
I have the “IN” on the relay connnected to IO4, and its being powered by an external 5v source. I can post some crappy photos if that would help? LOL
Cheers
Hi Kreggly,
I have tested all GPIO’s and there appears to be no change/spike in voltages. I have noticed when I’m monitoring the serial the button press is getting to the board, but not doing anything…
Sure, lets see some pictures.
@bennyrut,
Maybe try removing the default function. Could be this function is trapping all input changes and CAYENNE_IN(4) never gets called.
still no go Craig. I have commented out…
and still the same result, but obviously no output on the serial monitor.
I have a button configured like this…
Does the channel refer to the digital pin or the virtual pin? Maybe I’m missing something with the digital and virtual pins?
Ben
What do you show under device settings?
Should be Virtual Channels when selecting GPIO.
