Esp relaywith reset
hi, I’m using an esp286, everything works perfectly, but when it goes off the power and restart does not come back as a dashboard setting but starts with the relay all closed, can you help me?
//#define CAYENNE_DEBUG
#include “DHT.h”
#define DHTPIN D2
#define DHTTYPE DHT22
#define VIRTUAL_PIN 3
#define RELAY_DIGITAL_PIN D1
#define VIRTUAL_PIN2 4
#define VIRTUAL_PIN3 5
#define VIRTUAL_PIN4 6
#define RELAY_DIGITAL_PIN2 D3
#define RELAY_DIGITAL_PIN3 D4
#define RELAY_DIGITAL_PIN4 D5
char ssid[] = “”;
char wifiPassword[] = “”;
char username[] = "
char password[] = "
char clientID[] = "
unsigned long lastMillis = 0;
DHT dht(DHTPIN, DHTTYPE);
pinMode(RELAY_DIGITAL_PIN, OUTPUT);
pinMode(RELAY_DIGITAL_PIN2, OUTPUT);
pinMode(RELAY_DIGITAL_PIN3, OUTPUT);
pinMode(RELAY_DIGITAL_PIN4, OUTPUT);
dht.begin();
float h = dht.readHumidity();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
Serial.print(“Humidity: “);
Serial.print(h);
Serial.print(” %\t”);
Serial.print(“Temperature: “);
Serial.print(t);
Serial.print(” *C “);
Serial.print(f);
Serial.print(” *F\t”);
lastMillis = millis();
Cayenne.virtualWrite(1, h);
Cayenne.virtualWrite(2, t);
Serial.print(h);
Serial.print("Temperature: “);
Serial.print(t);
Serial.println(” *C ");
CAYENNE_IN(3)
if (currentValue == 0) {
digitalWrite(RELAY_DIGITAL_PIN, HIGH);
} else {
digitalWrite(RELAY_DIGITAL_PIN, LOW);
CAYENNE_IN(4)
{CAYENNE_LOG(“Got a value: %s”, getValue.asInt());
digitalWrite(RELAY_DIGITAL_PIN2, HIGH);
} else {
digitalWrite(RELAY_DIGITAL_PIN2, LOW);
CAYENNE_IN(5)
digitalWrite(RELAY_DIGITAL_PIN3, HIGH);
} else {
digitalWrite(RELAY_DIGITAL_PIN3, LOW);
CAYENNE_IN(6)
digitalWrite(RELAY_DIGITAL_PIN4, HIGH);
} else {
digitalWrite(RELAY_DIGITAL_PIN4, LOW);
CAYENNE_CONNECTED()
CAYENNE_LOG(“Connection established”);
Cayenne.syncAll();
So your trying to get the relay to default to on when the esp restarts?
whatever state you want of the relay, write it in void setup.
no I would like it to start the same way I left it in the dashboard, or at least that the dashboard perceive the status of the relay in order to read the status of the relay, to indent us as does the native dashboard of cayenne with arduino one
You could write in setup after Cayenne.begin to call a virtual write to your relay actuator pin. That way you could sync the state to either on or off when it powers on. I don’t think there is a way using MQTT to get the dashboard to resend its button states on connection. I’m not sure though
How can I then send the status of the real relays to the dashboard?
To get the state of the relay on power on to the dashboard, look at my example below that runs in setup. It sets the dashboard states to the same as the arduino so no matter what the last state was on the dashboard, on reset both match. randomProgram is a button, program and wait are sliders on the dashboard.
If your trying to get the dashboard state on reset, I don’t believe thats possible right now. I don’t believe the Cayenne.syncAll() does anything with MQTT connection, I think thats just for the older Cayenne connection. Someone correct me if I’m wrong :slight_smile:
byte randomProgram = 0;
byte program = 4;
int wait = 200;
	system_update_cpu_freq(160);
	system_phy_set_max_tpw(82);
	wifi_set_opmode(0x01);
	// Serial.begin(9600);
	Wire.begin(sdaPin,sclPin);
	Wire.setClockStretchLimit(40000);
    //below sets the dashboard states, needs to be after Cayenne.begin()
	Cayenne.virtualWrite(2, randomProgram, "digital_actuator", "d");
	Cayenne.virtualWrite(1, program, "analog_actuator", "null");
	Cayenne.virtualWrite(3, wait, "analog_actuator", "null");
	Cayenne.virtualWrite(20, 0, "digital_sensor", "d");
grazie mille:relaxed:
