ESP32 won't connect to cayenne
I downloaded the cayenne esp32 library off github and my esp32 is running other code fine. I ran the sample wifi code to ensure it was connecting to the internet, all fine.
I selected the sparkfun esp8266 thing on the my devices part, then in the code I changed the username password and client ID to match the cayenne website, and typed in my wifi details, when I uploaded the code there are no errors looks like it is working, but then on the cayenne webite it is waiting for board to connect. The board never connects, so I don’t know what to do next. Please help ASAP.
add #define CAYENNE_DEBUG in your code and check serial monitor for any error.
I done this, there is nothing printing to my serial monitor and it is at the correct baud-rate.
can you share the link of the device you are using.
https://learn.sparkfun.com/tutorials/esp32-thing-hookup-guide/introduction
Thank you for your help!
have you installed the ESP32 Board Package https://github.com/espressif/arduino-esp32/blob/master/README.md#installation-instructions ??
Yes there are all installed, board is working fine apart from not being able to connect to cayenne.
#include <WiFi.h>
const char* ssid = "yourNetworkName";
const char* password =  "yourNetworkPass";
  Serial.begin(115200);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
this is the code i used to connect my wifi connection. Everything was ok. Then below is the code i used to send to cayenne. Please anyone help!
// This example shows how to connect to Cayenne using an ESP32 and send/receive sample data.
// Make sure you install the ESP32 Board Package and select the correct ESP32 board before compiling.
// To install the ESP32 Board Package follow the instructions here: https://github.com/espressif/arduino-esp32/blob/master/README.md#installation-instructions.
#include <CayenneMQTTESP32.h>
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Steps:
  1. If you have not already installed the ESP32 Board Package install it using the instructions here: https://github.com/espressif/arduino-esp32/blob/master/README.md#installation-instructions.
  2. Select your ESP32 board from the Tools menu.
//#define CAYENNE_DEBUG
char ssid[] = “vodafone-3C65”;
char wifiPassword[] = “xxxxxxx”;
char username[] = “6xxxxxx”;
char password[] = “4cxxxxxxx”;
char clientID[] = “2xxxxxxx”;
//CAYENNE_IN(1)
//for channel 1 commands.
getValue.setError(“Error message”); // uncomment this line
I have added getValue.setError(“Error message”); and got the error [532] WiFi not present.
Ran it a few times and the error message is intermittent?
any ideas??
hey got it working,
for anyone with the same issue this is the code i got to work.
Steps:
#define EspSerial Serial
#include <WiFi.h>
const char* ssid = "xxxxxxxxxxxxxxx";
const char* password =  "xxxxxxxxxxxxxxx";
char ssidc[] = "vxxxxxxxxxxxxxxx";
char passwordc[] =  "xxxxxxxxxxxxxxx";
char username[] = "xxxxxxxxxxxxxxx";
char wifipassword[] = "xxxxxxxxxxxxxxx";
char clientID[] = "2xxxxxxxxxxxxxxx";
    delay(500);
	Cayenne.begin(username, wifipassword, clientID, ssidc, passwordc);
//CAYENNE_IN(1)
//getValue.setError();
Thank you!!!
I thought I was going crazy. Your solution helped get the Adafruit HUZZAH32 Feather to run the sample!
Hopefully Cayenne update the library or sample code so it works first time out the box.
I am using the same code but can’t upload the code to esp32. Compiling is ok but uploading fails showing some errors. I have use Blynk with esp32 and its work fantastic but Cayenne IOT platform doesn’t. I am trying to connect with Cyenne my devices but fails again again. I have done so many install, unnstall library, arduino IDE, esp32 board addition etc but fail to work with Cayenne IOT mydevices.com.
#14
follow the instruction from here https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/Connections/ESP32/ESP32.ino and if you can share what error you are facing we can help you out.
#15
Thanks shramik.
[526] WiFi not present error in cayenne MQTT esp32 board (After uploading)
Collegiate, exist status 1 error during uploading. (During uploading);
#16
#17
Sorry for late reply. It is now working. There was wifi credentials problem for cayenne.begin(). SSID/cSSID; password/cpassword.
