Esp8266-01 as wifi shield
Hi all
I want to connect my arduino mini pro to Cayenne via esp8266-01 for some IoT project
is it possible to use esp8266-01 as a WiFi shield to connect to Cayenne?
Thanks,
Lion
Hello Sir,
I am not sure if this is possible, but here is your must read post: Esp8266
Also @kreggly is the person that can answer best to your question.
Thank you.
Hi @lionlebron996, welcome to the Cayenne Community.
You’ll be interested in this post as well, which has some example code for using the ESP8266 as a wifi shield for an Arduino.
Bumping this old thread to share that we’ve just provided support in our MQTT Arduino library for using ESP8266 as a shield :slight_smile: We’ve done basic testing and works well. Give it a try for your project and let us know how it works out for you !
