ESP8266-12E, Arduino, Relay switch, Light on Dashboard
it´s my second project.
It was just an Idea to make it. It was tricky but its run very well.
Hope, this will help some Newbies with a ESP and Cayenne, yeah its sometimes tricky !
With this Sketch, you can switch just an Led on/off and a 2 way Relay for some electrics on the Cayenne Dashboard.
The Cayenne_IN function works well !
Yoel have to configure widgets and the Channels on Cayenne Dashboard !
Hi Community,
20171212_090329|666x500
Arduino Sketch
#define CAYENNE_DEBUG
#define CAYENNE_PRINT serial
char ssid[] = "***";
char wifiPassword[] = "***";
char username[] = "*****";
char password[] = "*****";
char clientID[] = "*****";
  pinMode(2, OUTPUT);
  digitalWrite(2, LOW);
  pinMode(5, OUTPUT);
  digitalWrite(5, LOW);
  pinMode(2, OUTPUT);
  pinMode(4, OUTPUT);
  digitalWrite(4, HIGH);
CAYENNE_IN(6)
  if (currentValue == 1)
    //do whatever you want when you turn on the button on cayenne dashboard
    digitalWrite(2, HIGH);
  else
    //do whatever you want when you turn off the button on cayenne dashboard
CAYENNE_IN(7)
    digitalWrite(5, HIGH);
  else
CAYENNE_IN(8)
    digitalWrite(4, LOW);
  else
Nice project, thanks for sharing!
Great project!
very nice @Sven, very nice! your sketch showed me some nuances in use
