Esp8266 & ds18b20
I’m connecting ESP8266 with waterproof temperature sensor DS18B20 but I’m always getting 185 F, I don’t know why… Can you please help me
have a look at this example Converting Cayenne Arduino LIbrary sketches to Cayenne MQTT Arduino
Hello, I have also had many problems to reconnect with my arduino + ESP8266, I tried to follow the tutorial to update to MQTT but I do not achieve it, help pls
We need more info. Errors? Code?
I was using the following connection and skecth for a long time without problems, now I do not know how to update to the new cayenne change to continue uploading the temperature data via WIFI. I would appreciate any advice or suggestion.
Greetings.
#include <ESP8266_HardSer.h>
#include <OneWire.h>
char token[] = "urkpwh44hq";
char ssid[] = "HTC";
char password[] = "aa7aac1f75d1";
#define VIRTUAL_PIN1 V1
#define VIRTUAL_PIN2 V2
#define VIRTUAL_PIN3 V3
#define VIRTUAL_PIN4 V4
#define VIRTUAL_PIN5 V5
const int tmpPin1 = 2;
const int tmpPin2 = 3;
const int tmpPin3 = 4;
const int tmpPin4 = 5;
const int tmpPin5 = 6;
OneWire oneWire1(tmpPin1);
OneWire oneWire2(tmpPin2);
OneWire oneWire3(tmpPin3);
OneWire oneWire4(tmpPin4);
OneWire oneWire5(tmpPin5);
DallasTemperature sensors1(&oneWire1);
DallasTemperature sensors2(&oneWire2);
DallasTemperature sensors3(&oneWire3);
DallasTemperature sensors4(&oneWire4);
// Set ESP8266 Serial object
#define EspSerial Serial
ESP8266 wifi(EspSerial);
  EspSerial.begin(115200);
  delay(10);
  sensors1.begin();
   sensors2.begin();
CAYENNE_OUT(VIRTUAL_PIN1)
	sensors1.requestTemperatures();
	Cayenne.celsiusWrite(VIRTUAL_PIN1, sensors1.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN2)
  sensors2.requestTemperatures();
  Cayenne.celsiusWrite(VIRTUAL_PIN2, sensors2.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN3)
  sensors3.requestTemperatures();
  Cayenne.celsiusWrite(VIRTUAL_PIN3, sensors3.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN4)
  sensors4.requestTemperatures();
  Cayenne.celsiusWrite(VIRTUAL_PIN4, sensors4.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN5)
  Cayenne.celsiusWrite(VIRTUAL_PIN5, sensors5.getTempCByIndex(0));
The token connection method has been disabled, you will have to use MQTT. It looks like your code was cut off a bit at the end, but this link should help you.
Do you know what this error is?
" Not used: C:\Users\Ricardo\Documents\Arduino\libraries\Cayenne-MQTT-ESP8266-master "
follow this step by step https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/Connections/ESP8266Shield/ESP8266Shield.ino and here is old tutorial https://eldontronics.wordpress.com/2017/08/28/beginning-iot-with-esp8266-01-wifi-module-and-cayenne-iot-platform/comment-page-1/#comment-17
