ESP8266 (LinkNode D1) can't read digital switch state
I have a PIR sensor working on this board with Cayenne but for some reason I just can’t get the state of my push button to be read. I would like for someone to have a look at the code below and let me know if this is a mistake in the code. If not I will keep on checking hardware.
Thanks!
#include "CayenneDefines.h"
char token[] = "*********";
char ssid[] = "******";
char password[] = "********";
// Virtual Pin of the Digital Motion Sensor widget.
#define VIRTUAL_PIN V1
#define VIRTUAL_PIN1 V2
// Digital pin the motion sensor is connected to. Do not use digital pins 0 or 1 since those conflict with the use of Serial.
const int motionSensorPin = 4;
const int frontDoor = 3;
  //pinMode(frontDoor, INPUT);
  //digitalWrite(frontDoor, LOW);
  checkSensor();
int previousState = -1;
int currentState = -1;
int fdState = -1;
void checkSensor()
  if (currentMillis - previousMillis >= 250) {
    currentState = digitalRead(motionSensorPin);
    fdState = digitalRead(frontDoor);
    //Serial.println("PIR State: ");
    //Serial.print(currentState);
      Cayenne.virtualWrite(VIRTUAL_PIN1, fdState);
      Cayenne.virtualWrite(VIRTUAL_PIN, currentState);
      previousState = currentState;
I would never assume that your Arduino is going to start as all input pins, although they probably are. It’s just good programming to explicitly assign them with pinMode.
I think the issue you are facing is pin remapping.
Check this out - http://linksprite.com/wiki/index.php5?title=LinkNode_D1
#define MOTION_PIN D4 //GPIO4
#define DOOR_PIN D0 //GPIO3
int fdState = -1;
  pinMode(DOOR_PIN, INPUT);
  pinMode(MOTION_PIN, INPUT);
  checkSensor();
void checkSensor()
    currentState = digitalRead(MOTION_PIN);
    fdState = digitalRead(DOOR_PIN);
I finally got it straight. I needed to set thepin mode to pinMode(MOTION_PIN, INPUT_PULLUP);
Ahh… That’s great. Personally I try not to rely on integral pull-ups. You may want to add an external resistor instead.
