ESP8266 No debug on serial monitor
Following instructions from this video
Project works because I can turn on/off an LED on pin 13, but, I see no debug on the serial monitor.
Using a Huzzah ESP8266 breakout board with this code
#define CAYENNE_DEBUG
char ssid = “…”;
char password = “…”;
char username = “a…c”;
char mqtt_password = “5…0”;
char client_id = “5…e”;
Cayenne.begin(username, mqtt_password, client_id, ssid, password);
pinMode(13,OUTPUT);
digitalWrite(13, LOW);
CAYENNE_IN(0) {
digitalWrite(13, !getValue.asInt());
Hello Sir,
for a serial debug, you have to use the command: Serial.begin(9600); with any speed related to your needs!
Thank you, that did the trick!
Forgot that this is debugging 101!
Should I consider the theme as closed ? :slight_smile:
Yup, thanks
