ESP8266 with ADXL345, i am not getting plot in Cayenne Dashboard
// With the following code, i could able to get serial plot in Arduino, but i am unable to get the real time plot in Cayenne dashboard. Requested to fix my code (and i am basically from Civil Engineering background)
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
char ssid[] = "Almighty";
char wifiPassword[] = "12345";
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
/* Assign a unique ID to this sensor at the same time */
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
void displaySensorDetails(void)
  sensor_t sensor;
  accel.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" m/s^2");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" m/s^2");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" m/s^2");
  Serial.println("");
  delay(500);
void displayDataRate(void)
  Serial.print  ("Data Rate:    ");
  switch(accel.getDataRate())
    case ADXL345_DATARATE_3200_HZ:
      Serial.print  ("3200 ");
      break;
    case ADXL345_DATARATE_1600_HZ:
      Serial.print  ("1600 ");
      break;
    case ADXL345_DATARATE_800_HZ:
      Serial.print  ("800 ");
      break;
    case ADXL345_DATARATE_400_HZ:
      Serial.print  ("400 ");
      break;
    case ADXL345_DATARATE_200_HZ:
      Serial.print  ("200 ");
      break;
    case ADXL345_DATARATE_100_HZ:
      Serial.print  ("100 ");
      break;
    case ADXL345_DATARATE_50_HZ:
      Serial.print  ("50 ");
      break;
    case ADXL345_DATARATE_25_HZ:
      Serial.print  ("25 ");
      break;
    case ADXL345_DATARATE_12_5_HZ:
      Serial.print  ("12.5 ");
      break;
    case ADXL345_DATARATE_6_25HZ:
      Serial.print  ("6.25 ");
      break;
    case ADXL345_DATARATE_3_13_HZ:
      Serial.print  ("3.13 ");
      break;
    case ADXL345_DATARATE_1_56_HZ:
      Serial.print  ("1.56 ");
      break;
    case ADXL345_DATARATE_0_78_HZ:
      Serial.print  ("0.78 ");
      break;
    case ADXL345_DATARATE_0_39_HZ:
      Serial.print  ("0.39 ");
      break;
    case ADXL345_DATARATE_0_20_HZ:
      Serial.print  ("0.20 ");
      break;
    case ADXL345_DATARATE_0_10_HZ:
      Serial.print  ("0.10 ");
      break;
    default:
      Serial.print  ("???? ");
      break;
  Serial.println(" Hz");
void displayRange(void)
  Serial.print  ("Range:         +/- ");
  switch(accel.getRange())
    case ADXL345_RANGE_16_G:
      Serial.print  ("16 ");
      break;
    case ADXL345_RANGE_8_G:
      Serial.print  ("8 ");
      break;
    case ADXL345_RANGE_4_G:
      Serial.print  ("4 ");
      break;
    case ADXL345_RANGE_2_G:
      Serial.print  ("2 ");
      break;
    default:
      Serial.print  ("?? ");
      break;
  Serial.println(" g");
void setup(void) {
#ifndef ESP8266
  while (!Serial); // for Leonardo/Micro/Zero
#endif
  Serial.println("Accelerometer Test"); Serial.println("");
  /* Initialise the sensor */
  if(!accel.begin())
    /* There was a problem detecting the ADXL345 ... check your connections */
    Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
    while(1);
  /* Set the range to whatever is appropriate for your project */
  accel.setRange(ADXL345_RANGE_16_G);
  // displaySetRange(ADXL345_RANGE_8_G);
  // displaySetRange(ADXL345_RANGE_4_G);
  // displaySetRange(ADXL345_RANGE_2_G);
  /* Display some basic information on this sensor */
  displaySensorDetails();
  /* Display additional settings (outside the scope of sensor_t) */
  displayDataRate();
  displayRange();
  Serial.println("");
void loop(void) {
  if (millis() - lastMillis > 100) {
    lastMillis = millis();
  /* Get a new sensor event */
  sensors_event_t event;
  accel.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  //Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print("  ");
  //Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print("  ");
  //Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print("  ");Serial.println("m/s^2 ");
  //delay(10);
  //For telemetry viewer uncomment/comment this
  Serial.print(", ");
  Serial.print(", ");
  Serial.println("");
CAYENNE_OUT(1)
  Cayenne.virtualWrite(1, millis());
CAYENNE_IN(1)
I’m seeing lots of curly bracket mismatches. Although I’m not sure it will do what you want it to do, try the code below. It should at least compile. What exactly are you trying to do?
#include <Wire.h>
char ssid[] = "";
char wifiPassword[] = "";
  sensor_t sensor;
  Serial.println("");
  delay(500);
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
    default:
      break;
      break;
      break;
      break;
      break;
    default:
      break;
void setup(void) {
#ifndef ESP8266
#endif
  if(!accel.begin())
    while(1);
  displayDataRate();
  displayRange();
  Serial.println("");
void loop(void) {
	  //delay(10);
	  Serial.print(", ");
	  Serial.print(", ");
	  Serial.println("");
CAYENNE_OUT(1)
CAYENNE_IN(1)
Thanks for your reply,
I actually wanted to get ADXL345 accelerometer readings in my Cayenne dashboard, just like how we get in ‘Serial Monitor’ and ‘Serial Plotter’.
Thank you
i wanted something like this
I am having doubt in this part !
CAYENNE_OUT(1)
@amruthrajsagar to send value to cayenne dashboard you need this line in your loop:
" Cayenne.virtualWrite(1, x);"
where 1 is the MQTT channel and x is the value you want to send . when you run your code it will get connected and add a value widget to your dashboard automatically. click add and change the setting as you want.
try the below code and let me know
#include <Wire.h>
char ssid[] = "";
  sensor_t sensor;
  Serial.println("");
  delay(500);
  switch (accel.getDataRate())
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
      break;
    default:
      break;
  switch (accel.getRange())
      break;
      break;
      break;
      break;
    default:
      break;
void setup(void) {
#ifndef ESP8266
#endif
  if (!accel.begin())
    while (1);
  displayDataRate();
  displayRange();
  Serial.println("");
void loop(void) {
    //delay(10);
    Serial.print(", ");
    Serial.print(", ");
    Serial.println("");
    Cayenne.virtualWrite(1, event.acceleration.x);
    Cayenne.virtualWrite(2, event.acceleration.y);
    Cayenne.virtualWrite(3, event.acceleration.z);
Thanks a lot, i am now getting values…Cheers,
i will now work to get graph :slight_smile:
