I made an IOT FARM and i scheduled an event to turn off/on the light during the day . Everything was working properly but since 2 days the light doesn’t turn on/off
I can activate the light manually with no problem.
Once we get this issue sorted out, I’d love if you shared your project as inspiration for the rest of the community. We recently had a project contest and IoT Chilibot won the contest, your project sounds similar since it is IoT Farm.
Okay, back to this issue. There are a couple small bugs with Scheduling feature that we found, and are pushing fixes soon. Can you tell us what exactly the schedule is that is not working anymore. Screenshot might be easiest…
We plan to release some scheduling fixes today actually, within next 5 hours. Hopefully the release goes smoothly. Will be sure to update you once the release is finished!
First of all, I apologize for the scheduling bugs that you were experiencing. We’ve recently released some fixes for them (you don’t need to do anything to get these fixes), can you let me know if you still experience scheduling issue?
Argh. I was goin’ nuckin’ futz with this “trigger” issue. (I was…um…“prevented” from posting on this issue)
It’s been freaking me out since mid-December. My “triggers” weren’t reliably triggering events…sometimes it worked, sometimes it didn’t work.
I figured it was on the server side, -since I can “see” when the switch inputs go high or low, and the relays weren’t triggering. However, the “app” buttons always worked…just not the trigger events.
Now I’m trying to deal with the response delays (since I’m using switch inputs as limit switches for garage door controllers, remote gate controllers and curtain controllers). I’m wondering if it wouldn’t be better to “firmware” program the limit switches directly in the ESP8266 device, -bypassing the Cayenne server. Currently, the delayed response is >1.2 seconds when using the ESP12-e. It’s causing my motors to over-current when they hit their physical limits.
I’ve found out that I MUST use re-trigger able 1-shots (pulse stretchers) on my security motion detectors.
A momentary closure can’t be seen by Cayenne unless the closure lasts longer than 1.5 seconds. NOT good! So…that seems to be a solution for Cayenne.
