Failed to connect to updates.mydevices.com
I try to add my Raspberry Pi as a new device using Cayenne. I first tried to connect to my Raspberry Pi using iPhone App, but it was stuck at the first step (installing libraries). After several tries, I tried to install manually in my Pi using the following commands.
wget https://cayenne.mydevices.com/dl/rpi_7tdu4o8fmx.sh
sudo bash rpi_7tdu4o8fmx.sh -v
However, it keeps failing, and it repeatedly shows the following message.
(try: 10) https://updates.mydevices.com/raspberry/myDevices-1.0.tar.gz
Connecting to updates.mydevices.com (updates.mydevices.com)|54.148.225.117|:443… failed: Connection timed out.
Retrying.
(try: 11) https://updates.mydevices.com/raspberry/myDevices-1.0.tar.gz
Retrying.
and so on.
It seems the update server is down. Any idea?
Thanks.
Best,
Hello from Germany,
I’ve got the same problems while installing mydevices on the pi.
Thanks for help
Erhard
hello from french
i too have the same problem is the server are disconnected or update?
we have no info
cayenne is having a major update. so this might cause the problem.
how long for the end of the update because i can not install my raspberry and configure it
Hi @maximeeloy @erhardroth,
Are you able to try again with a new install?
~Benny
Hi
I am also trying to do a new install without success on the “Connecting to updates.mydevices.com” step. I am unable to ping 54.148.225.117 from either the Pi or my laptop. Suggests a server is down?
We’re investigating right now. Will update this thread.
~Benny
I have the same problem right now…Any idea?
Johana
I am another one with the same error
Mir geht es genauso, also warten wir ab bis wieder funktioniert
Hi Benny,
Thank you for the mail.
I’ve tried for serveral times. It seems, that the server is not available.
Erhard
⁣Gesendet mit BlueMail ​
Am 21. Dez. 2017, 00:44, um 00:44, Benny Estes mydevices@discoursemail.com schrieb:
hey everyone,
We’re looking into it. Will give update when I can!
~Benny
#14
@erhardroth @pumukl01 @jody @johana.panduro @rebrown @maximeeloy @kiwon.yun How are thinigs looking now?
~Benny
#15
always the same problem
pi@batiment:~ $ wget https://cayenne.mydevices.com/dl/rpi_3wnjy4fc25.sh
–2017-12-21 20:54:50-- https://cayenne.mydevices.com/dl/rpi_3wnjy4fc25.sh
Résolution de cayenne.mydevices.com (cayenne.mydevices.com)… 52.45.215.199, 34.231.97.124
Connexion à cayenne.mydevices.com (cayenne.mydevices.com)|52.45.215.199|:443… connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 1295 (1,3K) [binary/octet-stream]
Sauvegarde en : « rpi_3wnjy4fc25.sh.4 »
rpi_3wnjy4fc25.sh.4 100%[===================>] 1,26K --.-KB/s in 0s
2017-12-21 20:54:51 (9,06 MB/s) — « rpi_3wnjy4fc25.sh.4 » sauvegardé [1295/1295]
pi@batiment:~ $ sudo bash rpi_3wnjy4fc25.sh -v
rpi_3wnjy4fc25.sh
continuing as new install…
–2017-12-21 20:55:03-- https://updates.mydevices.com/raspberry/myDevices-1.0.tar.gz
Résolution de updates.mydevices.com (updates.mydevices.com)… 54.148.225.117
Connexion à updates.mydevices.com (updates.mydevices.com)|54.148.225.117|:443… échec : Connexion terminée par expiration du délai d’attente.
Nouvel essai.
–2017-12-21 20:57:16-- (essai : 2) https://updates.mydevices.com/raspberry/myDevices-1.0.tar.gz
#16
I’ve tried with the Android App.
Step 1: installing libaries run and run and run…
Am 21. Dez. 2017, 20:46, um 20:46, Benny Estes mydevices@discoursemail.com schrieb:
#17
Still failing to connect:
Retrying.
#18
Same problem here:
Connecting to updates.mydevices.com (updates.mydevices.com)|54.148.225.117|:443... failed: Connection
timed out.
Retrying.
#19
Damn,i thought i only had the problem…Add me to the list then…
#20
same problem here
