FAQ's
#22
Hi All,
I just became a member of this great website.
I have an issue whenever I try to add new switch to my device. There is no any icon in the list!
Any idea ? Is this web browser problem. On my phone it is working well.
#23
@marton.szoke welcome to the Cayenne community! Hope to keep seeing you around.
What browser are you using? Can you try first selecting a Pin in the above dropdown too?
#24
I tried under firefox and chrome too … same results.
Here is a new pic. of chrome selected pin . The drop down menu still does not work.
#25
I just downloaded the latest Arduino IDE (Ver. 1.8.0).
Questions:
Do the ESP12-e chips still prefer the “Generic 8266” board choice, or is the NodeMCU board a better choice?
(I suppose I could just dive in and start flashing
and find out myself, but I’m not set-up right now)
I see that after the latest Arduino IDE installation, I still have the Cayenne library installed- Is there anything else I may need to know re: Esp12-e/ESP8266?
The reason I ask- because of the un-availability of GPIO 14 and 16 (previously, you had to write/read to a virtual GPIO pin, then add code to the Cayenne simple framework on the Arduino IDE ESP device flash). I’d hate to design the GPIO expander chip in my PC boards, -but I’ve gotta have more GPIOs. Wishing I had 6 GPIO rather than the 4 usable GPIO (4, 5, 12, 13).
I’m TOLD (never observed) that GPIO 16 has a pull-down resistor, while all other GPIOs have software programmable pull-ups. does anyone know for sure? I get conflicting info on the internet.
I tried designing a PC board using GPIO 2 and GPIO 0, using 1 shot delays.
Bottom line-
WARNING: do NOT try to use GPIO 0 and GPIO 2! Even if you pull the lines high, -just…don’t use GPIO 0 and GPIO 2!
GPIO 0 is used, of course, to enter FLASH programming mode.
GPIO 2 is used to address SD card memory.
Even if you tie GPIO 2 high, it’s connected to the blue LED/1.8K current limiting resistor to 3v3.
It’s best to program GPIO 2 as a generic digital OUTPUT,
I label this as “Blue LED”.
So- is Esp12-e GPIO 14 and 16 now “easily” addressable? Thanks!
#26
This might have been fixed already but it’s working for me. Are you still having this issue?
#27
Virtual pins are currently the only way. Is there a reason you don’t want to use them until the ESP is supported?
#29
-because I’m a horribly crummy, uneducated simpleton who needs the code literally pasted in front of me.
#31
Sorry Adam , I still have same issue , no drop down list of choose icon does not work.
#32
hi @bestes i have raspberry pi 3 model B and i cannot remote access "Desktop not responding
can you help me to solve this issue
#33
Guys, BT is more than important it is mandatory to have, Please help the huge number of devs that are waiting for be able to use Cayenne !!! Tks
