Finding out the state of a pin using cayenne
Using Pi, how can a magnetic switch on a window triggers an alert when the widow is opened.
Thank you for your help.
Mo
Hi @monekpublic
Thanks for joining the Cayenne Community, excited to see how your project comes along.
For this case, you could monitor the state of the pin with a Generic Digital Input widget from Add New > Widget > Sensors > Generic. Here is our tutorial on that particular input (using a pushbutton switch, but the same general logic applies.)
Once that is created and reading the pin value into your Cayenne dashboard, you can add trigger(s) for it via Add New > Trigger which send you SMS or email when the switch is in the desired state.
