First attempt at mqtt not compiling
Hi guys, this is my first attempt at using mqtt with the esp8266 and i havent’ been able to get compile the cayenne mqtt sketch for the past few hours. i get this error below
I’m using a wemos nodemcu with oled screen.
any idea what the problem could be from my error log?
Build options changed, rebuilding all
In file included from C:\Users\W4R10C~1\AppData\Local\Temp\arduino_modified_sketch_695137\ESP8266Shield.ino:21:0:
C:\Users\w4r10ck3r\Documents\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:29:34: fatal error: ESP8266SerialLibrary.h: No such file or directory
#include “ESP8266SerialLibrary.h”
compilation terminated.
exit status 1
Error compiling for board Generic ESP8266 Module.
@aotrakstar use this code and make sure you have CayenneMQTT library installed.
//#define CAYENNE_DEBUG
char ssid[] = "ssid";
unsigned long lastMillis = 0;
		lastMillis = millis();
		//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
I tried your sktech, now i get this error :slight_smile:C:\Users\w4r10ck3r\Documents\AVIS\cayenne_esp8266_mqtt\cayenne_esp8266_mqtt.ino:6:32: fatal error: CayenneMQTTESP8266.h: No such file or directory
I am positive that the CayenneMQTTESP8266.h file is present in the library.
Where is CayenneMQTTESP8266.h located ? This sketch should compile without errors .
My bad… it failed to compile since because i had downloaded the arduino mqtt zip file instead of the esp8266. So i no longer get that error. this is the new error while compiling
C:\Users\w4r10ck3r\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp:623:14: error: ‘WPS_CB_ST_UNK’ was not declared in this scope
Sounds like that error is caused by not having the board installed in the IDE Follow these instructions to get that installed and let us know if it works!
The installation instruction link is dead.
Works for me, try this one https://github.com/esp8266/Arduino
I have deleted and reinstalled the ide as well as the esp8266 core and its still one error or the other:
C:\Users\w4r10ck3r\Documents\Arduino\libraries\Cayenne-MQTT-ESP-master\src/CayenneArduinoMQTTClient.h:46:7: note: no known conversion for argument 1 from ‘WiFiClient’ to ‘int&’
Can you post the code you are using?
i have same problem
Arduino: 1.8.6 (Windows 7), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
Multiple libraries were found for “CayenneMQTTESP8266Shield.h”
ceklib:21:38: error: CayenneMQTTESP8266Shield.h: No such file or directory
Used: C:\Users\dika zahra\Documents\Arduino\libraries\CayenneMQTT
Not used: C:\Users\dika zahra\Documents\Arduino\libraries\Cayenne-MQTT-Arduino-master
exit status 1
option enabled in File -> Preferences.
help me please
#14
Please don’t post in multiple topics
