- Device & model you are using (Ex: Pi 2 Model B or Arduino Uno with W5100 ethernet shield)
Raspberry Pi zero with Jessie - What dashboard are you using? (Web, iOS, Android)
iPhone 5c iOS - Please describe the bug / issue as detailed as possible. Attaching the code and any relevant screenshots would be very helpful!
After many attempts I have fixed the adding of bmp 180 sensor. Try to use this command on the ssh terminal:
sudo raspi-config → select Advanced Options → Select i2c and enable the i2c port.
