[Fixed] Can't rename Widgets on Android App
I added a BMP180 via the dashboard. This adds 2 widgets. Pressure and Temperature,
Although they’re both labeled as “Pressure”, I renamed the one to Temperature.
On the App, both show as pressure, without the option to rename.
If I remove them on the App side, and add again, I can set a name, but again, it’s for both.
Also, after removing the old widgets are still on the dashboard
Hey Derik,
Yikes, we’ll fix this. Thank you so much for reporting!
Should be able to rename widgets now. You should be asked in-app to update Cayenne.
Works nicely on my Nexus.
Ian
