Flow Meter help with reading data
@aniederauer there is code above given by @ognqn.chikov that calculates liters but it seems he had a problem with it. give it a try and let us know.
Hello. I’ve been testing the code above. I got some good answers. but I can not modify it to have as one of the final answers the total liters spent.
also due to some “noise” by some mistake of assembly, is summing daily liters. I’m going to work on this too.
hello, i have the same problem just like you. i am able to see the output in the serial monitor but not on cayenne. can you please help?
@syazwin.snr you need to swift to cayenne MQTT. Converting Cayenne Arduino LIbrary sketches to Cayenne MQTT Arduino
in your code there is no command which sends value to cayenne.
can you help me with the command?
have you shifted to MQTT?
#define Cayenne_Alcohol V1
const int VIRTUAL_PIN = 0;
const int VIRTUAL_PIN = 1;
const int VIRTUAL_PIN = 2;
char username[] = "";
char password[] = "";
char clientID[] = "";
int mq3_analogPin = A0; // connected to the output pin of MQ3
byte red=4, green=5, yellow=6; // pins for leds
// remember 100 to 1000 ohm resistor in series with each LED
float alcohol = 0;
void newFunctionName (int VIRTUAL_PIN)
{Cayenne.virtualWrite(Cayenne_Alcohol,alcohol,"voltage", "V");}
  Cayenne.begin ("username", "password", "clientID");
  pinMode(red,OUTPUT);
  pinMode(yellow,OUTPUT);
  pinMode(green,OUTPUT);
  Serial.print("Alcohol value:");
  Serial.begin(9600); // open serial at 9600 bps
  // give ample warmup time for readings to stabilize
  int mq3_value = analogRead(mq3_analogPin);
  float voltage = mq3_value* (5.0/1023.0);
  Serial.println(mq3_value);
  Serial.print("Voltage(V)");
  Serial.println(voltage);
  if (mq3_value<400)
    digitalWrite(green,HIGH);
    delay(1000);
    digitalWrite(green,LOW);
  else if(mq3_value>900)
    digitalWrite(red,HIGH);
    delay(1000);
    digitalWrite(red,LOW);
  else
    digitalWrite(yellow,HIGH);
    delay(1000);
    digitalWrite(yellow,LOW);
  delay(100); //Just here to slow down the output.
can you please check my coding?
what’s the error here?
in your code the “alcohol” value is always zero. rest i have changed.
float alcohol = 0;
unsigned long lastMillis = 0;
    lastMillis = millis();
    Cayenne.virtualWrite(0, alcohol,"voltage", "V");
  if (mq3_value<400)
    delay(1000);
    delay(1000);
  else
    delay(1000);
thankyou so much sir! but stated here the MQTT connection failed, error 5. can i know how to slove this?
check your MQTT credential.
i’ve create the new one account to have the new set of credential. but it still doesnt work. can you please help me?
what error you are getting.
MQTT connect failed, error 5
post the code you are using.
char username = “xxxx”;
char password = “xxxx”;
char clientID = “xxxx”;
float alcohol = 0;
Cayenne.begin(“username”, “password”, “clientID”);
Serial.print(“Alcohol value:”);
Cayenne.virtualWrite(0, alcohol,“voltage”, “V”);
Serial.print(“Voltage(V)”);
if (mq3_value<400)
delay(1000);
delay(1000);
else
delay(1000);
CAYENNE_OUT_DEFAULT()
Cayenne.celsiusWrite(1, 22.0);
Cayenne.luxWrite(2, 700);
Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
CAYENNE_IN_DEFAULT()
before going further, add a new device and add your MQTT credential into this simple code.
	if(millis() - lastMillis > 10000) {
		//Cayenne.luxWrite(2, 700);
sorry, im just a beginner. but what do you mean by “add new device” :sweat_smile:
have a look at this: Adding a New Device using MQTT
follow step 3 and add MQTT credential into the code i gave above.
