Generic PWM Output
    Arduino
    Web
Refreshing the dashboard page will resend PWM values.
Also not quite sure how to reproduce this but I’m getting some weird behavior from the values of the slider. Setting a value then going to another page then coming back and changing the value then going to another page and back again sometimes uses the first value.
