Getting "Offline" after using virtualWrite
Hello guys, my Cayenne is getting offline for about 15 seconds everytime I send a “virtualWrite” command, I wanna know what’s wrong with my code
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
#include <CayenneDefines.h>
#include <CayenneEthernetClient.h>
char token[] = "xxxxxxxxx";
const int buttonPin = 2;
int buttonState = 0;
  Cayenne.begin(token);
  pinMode(buttonPin, INPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    Cayenne.virtualWrite(V0, "1");
Welcome to Cayenne!
First thing I notice is you are sending a string and Cayenne doesn’t accept string. You might also be sending data too fast. Try:
    Cayenne.virtualWrite(V0, 1);
    delay(2000);
  else{
    Cayenne.virtualWrite(V0, 0);
Hello, It’s still getting disconnect. And I don’t know why it’s taking sooo long to connect…
delay(2000);
else{
That’s the code, right? And when I was using “0” and “1” it was working!!
Edit:
I had to add delay(2000); in else condition. It’s working perfecly now!! Thanks a lotttt
Yep, my bad, meant to put it there too… Glad to hear it’s working!
