Google assistant integration?
I have a project where I can control the air conditioning unit through a raspberry and cayenne.
I’m looking to see if I could trigger the virtual cayenne button through the google assistant.
It seems like you don’t support it directly yet but I think I may be able to come up with something going through the REST api.
Do you feel it would be possible?
What would be a high level overview of the REST calls that should be performed to trigger a virtual button press?
Wow is it as easy as this?
you can give it a try. it will awesome if you can get this working.
