I added and removed same device from dashboard, Rak wireless RAK811.
Now, I there is not the widget location (map) but only RSSI and SNR; at start there was map too.
Then I removed, by mistake, Map widget form dahboard
I can see RSSI and SNR updated from TTN.
I tried to remove and add device, change Dev EUI , but without success.
How can I restore widget Location (map) on my Cayenne Dashborad ?
Hi @rf1 – could you send the DevEUI for the device (the current one you’re trying to use?) Then I can look at the payloads we’re receiving and see if they are being decoded properly on our end, I’m guessing they are not and that’s why your map widget isn’t displaying. Once I see the state they are in, I can give you some more advice on what to try next.
