Greyed out "Channel" when adding a digital input
  • Device & model you are using: Pi 2
  • What dashboard are you using? Web
I try and add a device, Add new - Device/widget - select Sensors - Generic - Digital input. I can select device, connectivity (change to intergrated GPIO) but channel is greyed out. What am I doing wrong?
Welcome to Cayenne!
That’s definitely odd, seems to be ok for me. Do you have any popup blockers like ublock? Sometimes they can do some funky things.
Can you share a screenshot?
Thank you and thank you for the reply.
I tried a different browser with no pop-ups but still the same results. See screen shot. When I run my mouse over “Channel” it changes to a red circle with a line in it. Add sensor is also greyed out.
See my reply to Adam.
