Growlight control w/ timers
This is a program for controlling my growlight for my plants. It has the option of two timers at 4 hrs or 8 hrs that will automatically turn it off if you want. Its all running on a Wemos D1 Mini what is stacked with a relay shield and a proto board that I have setup to drop the voltage from 12v(*from inside the light) to 5v for the board.
Something to note, CAYENNE_CONNECTED() and CAYENNE_DISCONNECTED() functions have to be enabled by modifying the cayenne library. Easy to do from other posts on here.
Will update pics of completed project in coming days.
Code:
#include <Arduino.h>
// #define CAYENNE_DEBUG Serial
// #define CAYENNE_PRINT Serial
#include "CayenneDefines.h"
#include <SimpleTimer.h>
SimpleTimer timer;
char token[] = "key";
char ssid[] = "devices";
char password[] = "pass";
#define relayPin 5
bool online = false;
int disco = 0;
byte relay;
unsigned long time1;
unsigned long onlineTime;
unsigned long prevTime;
unsigned long eightHrTmr;
unsigned long fourHrTmr;
unsigned long expire;
	// Serial.begin(9600);
	eightHrTmr = timer.setTimeout(28800000L, timerDone);
	fourHrTmr = timer.setTimeout(14400000L, timerDone);
	timer.disable(eightHrTmr);
	timer.disable(fourHrTmr);
	pinMode(BUILTIN_LED, OUTPUT);
	pinMode(relayPin, OUTPUT);
	timer.run();
	time1 = millis();
	if (relay == LOW)
			digitalWrite(relayPin, LOW);
	else
			digitalWrite(relayPin, HIGH);
void timerDone()
	relay = LOW;
	Cayenne.virtualWrite(V1, LOW);
	Cayenne.virtualWrite(V2, LOW);
	expire = 0;
CAYENNE_CONNECTED()
	online = true;
	digitalWrite(BUILTIN_LED, LOW);
	online = false;
	digitalWrite(BUILTIN_LED, HIGH);
	prevTime = millis();
	disco++;
CAYENNE_IN(V0)
	relay = getValue.asInt();
CAYENNE_IN(V1)
	int tmr4 = getValue.asInt();
	if (tmr4 == 1)
			if (timer.isEnabled(fourHrTmr))
					delay(1);
			else
					timer.enable(fourHrTmr);
					expire = (millis() + 14400000L);
	else
			expire = 0;
CAYENNE_IN(V2)
	int tmr8 = getValue.asInt();
	if (tmr8 == 1)
			if (timer.isEnabled(eightHrTmr))
					delay(1);
			else
					timer.enable(eightHrTmr);
					expire = (millis() + 28800000L);
	else
			expire = 0;
CAYENNE_OUT(V10)
	if (timer.isEnabled(fourHrTmr) || timer.isEnabled(eightHrTmr))
			Cayenne.virtualWrite(V10, ((expire - time1) / 1000) / 60);
	else
			Cayenne.virtualWrite(V10, 0);
CAYENNE_OUT(V23)
	Cayenne.virtualWrite(V23, disco);
CAYENNE_OUT(V24)
	float time2 = (time1 / 1000) / 60;
	Cayenne.virtualWrite(V24, time2);
CAYENNE_OUT(V25)
	onlineTime = ((time1 - prevTime) / 1000) / 60;
	Cayenne.virtualWrite(V25, onlineTime);
Post the pics when you get a chance!
-Benny
The Wemos D1 Mini and components are inside the light fixture so you don’t even see them. Will put up a couple more pics later today when I get the bulk of my plants under it :slight_smile:
Updated code as I was having problems with the simpletimer library for some reason… this new way works better anyway.
char token[] = "zadg3a574d";
char password[] = "open4meplease";
#define relayPin 5
byte eightHrTimer;
byte fourHrTimer;
unsigned long expireTime;
int disco = 0;
byte relay;
	time1 = millis();
	if (relay == LOW)
	else
	if (fourHrTimer == 1 || eightHrTimer == 1)
			if (expireTime < millis())
					timerDone();
void timerDone()
	relay = LOW;
	Cayenne.virtualWrite(V0, LOW);
	fourHrTimer = 0;
	eightHrTimer = 0;
	expireTime = 0;
CAYENNE_CONNECTED()
	online = true;
	online = false;
	disco++;
CAYENNE_IN(V0)
CAYENNE_IN(V1)
	fourHrTimer = getValue.asInt();
	if (fourHrTimer == 1)
			expireTime = (millis() + 14400000L);
	else
			expireTime = 0;
CAYENNE_IN(V2)
	eightHrTimer = getValue.asInt();
	if (eightHrTimer == 1)
			expireTime = (millis() + 28800000L);
	else
			expireTime = 0;
CAYENNE_OUT(V10)
			Cayenne.virtualWrite(V10, ((expireTime - time1) / 1000) / 60);
	else
CAYENNE_OUT(V23)
CAYENNE_OUT(V24)
CAYENNE_OUT(V25)
Thanks for the update @vapor83, love it!
-Benny
Hi, can you tell me how much time is your light on/off and how I can modify these values?
I am new to these kind of stuff and try to understand it.
Beside to your project, I want to add an DHT11 shield to my D1 mini.
Thanks!
EDIT: I just saw that you have 4&8 hour timer.
@gaby_korupt this post may help you with your DHT11 code :slight_smile:
@gaby_korupt This is how you change you timer duration. In the code below, there is a number that is added to millis() and that is the duration counting in millis(). So, you can change that number to anything you want you time to be. ((14400000/1000)/60)/60 = 4hrs. So 1 hr would be 1000(millis per second)*60(seconds in a minute)*60(minutes in a hour). You add the “L” to the number because that forces it to be a “long” so the number is calculated correctly.
Does that make sense or were you asking something else. :slight_smile:
