HC-SR04 with Arduino Problem
I’m trying to connect Ultrasonic sensor with Cayenne. I’ll attach my code below… when i remove cayenne.begin(token) command sensor is working fine… if i add that sensor gives 0 as a output… i want to know what can i do for that…
#include <CayenneEthernet.h>
const int trigPin = 11;
const int echoPin = 10;
#define VIRTUAL_PIN V1
char token[] = "73p5v7l6yb";
int maximumRange = 200; // Maximum range needed
int minimumRange = 0; // Minimum range needed
long duration, distance; // Duration used to calculate distance
  Cayenne.begin(token);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
 digitalWrite(trigPin, LOW);
 delayMicroseconds(2);
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10);
 duration = pulseIn(echoPin, HIGH);
 //Calculate the distance (in cm) based on the speed of sound.
 distance = duration/58.2;
 if (distance >= maximumRange || distance <= minimumRange){
 /* Send a negative number to computer and Turn LED ON
 to indicate "out of range" */
 Serial.println("-1");
 else {
 /* Send the distance to the computer using Serial protocol, and
 turn LED OFF to indicate successful reading. */
 Serial.println(distance);
 //Delay 50ms before next reading.
 delay(50);
CAYENNE_OUT(VIRTUAL_PIN)
  Cayenne.virtualWrite(VIRTUAL_PIN, distance);
@sameeramannapperuma welcome to cayenne community.
before going any further, swift to cayenne mqtt library as it more stable and recommended. for this add cayenne mqtt library and then try this code.
int Trigger = 5;
int Echo = 6;
unsigned long lastMillis = 0;
    pinMode(Trigger, OUTPUT);
  pinMode(Echo, INPUT);
  digitalWrite(Trigger, LOW);
  digitalWrite(Trigger, HIGH);
  duration = pulseIn(Echo, HIGH);
  distance = (duration / 2) / 29.1;
  Serial.print(distance);
  Serial.println("Centimeter:");
  delay(500);
	if(millis() - lastMillis > 10000) {
		lastMillis = millis();
		Cayenne.virtualWrite(0, distance);
