I’m a newbie and i’m start a new project.
I have one actuator (lampe) and one sensor (temperature)
How to assemble the two programs to have only one ?
Thx for your help ^^
copy paste code from lamp into tempo.
Just like this ?
//Thermometre
char username[] = "";
char password[] = "";
char clientID[] = "";
#define SENSOR_PIN 0
#define VIRTUAL_CHANNEL 3
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(SENSOR_PIN));
//Lampe
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN 2 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
There are rehearsals … I can’t upload.
Remember to fill in your MQTT credentials
//Thermometre
Thanks ! ^^
